Have a 1987 E150 with 4.9 with EFI. Power at the fuel pump only comes on for two seconds or so when you turn the key on. Not sure what is causing it to stop
it is supposed to do that. Key on, pump comes on a few seconds to prime, then comes back on when it gets signal from distributor that engine is cranking. Do you have spark?
