Barometer reading via PCM
Old Dec 19, 2018 | 01:02 PM
Rumble phish's Avatar
Rumble phish
Tried to use the Torque app to get the barometer reading from the PCM but it doesn't show any data. Does anyone else know if this works?
Old Dec 19, 2018 | 01:13 PM
pdqford's Avatar
pdqford
Not sure, but back when we had a MAP sensor the PCM would grab the absolute pressure as soon as the key was on.
But I think everything now has a MAF sensor, so baro pressure is probably no longer critical. (Not sure how the EcoBoost measures air flow and boost pressure).
Old Dec 19, 2018 | 02:20 PM
Rumble phish
This is on a 2004 F150 with a 5.4L 3v engine. I've seen several videos from FordtechmakuLoco and he uses the Baro reading quite a bit on the '04 through the newest Fords , so it has to be available. The question is, how do we get the Torque app to display it?
Old Dec 19, 2018 | 07:32 PM
pdqford's Avatar
pdqford
Here’s what popped up on my TP:
Barometer (on Android device)
Barometric pressure (from vehicle)
Looks like you should be able to compare the two?
(Hopefully the TP expert will be along shortly).
Old Dec 19, 2018 | 07:44 PM
pdqford's Avatar
pdqford
Old Dec 20, 2018 | 10:16 AM
Rumble phish
Yeah, I get the same options - on Android or from vehicle. Neither work though . However, I did add them while the app was connected to the truck. According to your last post, that may affect if the PID works or not. I'll remove it and then set it up "off line" to see if that works.
Old Dec 22, 2018 | 09:51 AM
F150Torqued's Avatar
F150Torqued
Barometric pressure is at PID # 1127 on our 2004-2008 5.4ls
Mode & Pid: 221127
Long Name: Barometric Pressure
Short Nm: Baro
Min/Max 25/35
Units: InHg
Equation. A*0.13107
Header: Auto or Blank
Best to connect to digital gage and set decimals to 2.
Old Dec 23, 2018 | 08:33 PM
Rumble phish
Mode & Pid: 221127
Short Nm: Baro
Min/Max 25/35
Units: InHg
Equation. A*0.13107
So is there a way to get the torque app to show the data? It has a screen for it, but it isn't registering anything.
Old Dec 23, 2018 | 11:50 PM
F150Torqued
Yes. Go to >Settings >Manage Sensors and Custom PIDs >Add Sensor, answer YES to continue (even if you screw up -warning), and add a custom PID using the parameters above, press OK.
Then long tap on any dashboard where you want to place the Baro guage, >Select a 'Digital Gauge', >scroll through sensors and find the one you added "Barometric Pressure", and position it where you want. Long tap on that new digital gauge and >change configuration, >set number of decimals - to Two.
That's it.
Old Dec 25, 2018 | 08:18 PM
Rumble phish
Thanks!
That's it.
That worked like a charm!
Old Dec 26, 2018 | 08:03 AM
F150Torqued
Great! Makes my Christmas complete.
Old Oct 5, 2020 | 10:53 PM
Cosmic_Crunch's Avatar
Cosmic_Crunch
If we want the baro reading in Hz do we just leave the Equation as A and set Units to Hz? I'm assuming Hz is the default signal.
Old Jul 18, 2025 | 11:50 AM
o6S1D9e's Avatar
o6S1D9e
Trailering
Hey Torqued, what's your Baro Pressure?
Being that I live a few towns over from you I suspect that our barometric pressure reading should be the same. I'm at 151.6 after a KAM reset and new MAF.
Thanks
djousma
6.7L Power Stroke Diesel
13
Sep 9, 2018 05:57 PM
martin14sk
Aug 2, 2017 08:42 PM
Goose84
13
May 18, 2017 02:59 AM
Tugly
Dec 25, 2016 09:58 AM
derek0525
Jun 23, 2016 01:44 PM
