Driver's side window switch backwards
Old Dec 10, 2018 | 04:27 PM
Rumble phish's Avatar
Rumble phish
So, when I bought this truck I knew that the driver's side window switch was wonky. It goes down when you press up, and up when you press down. The auto feature is also backwards, in that it will go auto when going up (reverse guillotine)!
I figured it was a bad switch so I bought a new one, but it still does the same thing! WTH?!? Also, the passenger side rear window switch doesn't work, but I can roll it down from the driver's control. Figured a bad switch, right? Nope, put two new switches on it and it STILL doesn't work at the door. Motor is obviously good, because I can still roll it down from the drive's controls (yes, the window lock is off!!). WTH?!?
Old Dec 10, 2018 | 07:07 PM
projectSHO89's Avatar
projectSHO89
Sounds like the wires are reversed for the motor.
Old Dec 11, 2018 | 10:56 AM
alloro's Avatar
alloro
This happens when the motor housing is assembled 180 degrees off. Here is a generic video on how to fix the issue.
https://www.youtube.com/watch?v=yuxq...ature=youtu.be
Old Dec 11, 2018 | 12:01 PM
Rumble phish
Is this for real? I feel like someone is pulling my leg here ..
Old Dec 11, 2018 | 01:50 PM
ford390gashog's Avatar
ford390gashog
Ford changed the window polarity at the motor on trucks built after 8/9/2005. The fix is easy just swap the wires at the connector near the motor.
Old Dec 11, 2018 | 02:54 PM
Rumble phish
Couldn't I just swap the wires at the switch? I just have to figure out which wires go to the driver's side window motor...
Old Dec 11, 2018 | 06:20 PM
steve(ill)'s Avatar
steve(ill)
YEP..... that will work also.......... just find the two wires that run to the drivers motor.
Old Dec 12, 2018 | 11:39 AM
alloro's Avatar
alloro
Um, no one is pulling your leg, this is very real.
Old Dec 12, 2018 | 01:17 PM
Rumble phish
Yup, you're absolutely correct! I'm going to play with the old switch and see if I can isolate the wires that run the motor for the Driver's window and reverse them. If that's too much of a pain the butt, I'll do what you suggested.
Old Dec 12, 2018 | 01:20 PM
ford390gashog
You won't be able to swap wires at the switch without making it a hack job. Take the 3 mins and pull the door panel and get the short harness at the motor swapped.
Old Dec 12, 2018 | 01:47 PM
Rumble phish
Ugh! I know you're right. I just hate pulling the door panel off.
Old Dec 12, 2018 | 11:33 PM
canstacker's Avatar
canstacker
I recently changed out a window regulator assembly and the new one(Dorman) came with a wire harness adapter that reversed polarity if needed.
Old Dec 13, 2018 | 09:20 AM
alloro's Avatar
alloro
Now there's a plan.
Old Jul 26, 2024 | 12:28 PM
J-Rod Mad-ducks's Avatar
J-Rod Mad-ducks
1st Gear
This exact same thing, and I do mean exact same thing happened to me. Back passenger window would go up but not down from driver switch and front driver window was reversed. There is a wire coupler that links between the motor harness and the main door harness that switches the polarity for you that you can just buy and install (it just fits inbetween the connectors. The back window issue I fixed by just buying a new switch.
Krazyhorse93
Oct 14, 2016 02:00 PM
pathfindertango
Feb 20, 2015 01:20 PM
Steve Istvanek
1983 - 2012 Ranger & B-Series
Jan 15, 2015 09:32 PM
timbersteel
Sep 23, 2013 07:14 AM
Taboo
Jul 24, 2007 12:24 PM
