2002 Explorer window has me baffled.
Old Feb 18, 2015 | 01:22 PM
pathfindertango's Avatar
pathfindertango
Angry 2002 Explorer window has me baffled.
Let me just start off by saying I'm pretty good at diagnosing and fixing everything on mine and the Wife's Explorers.. But this one I can't figure out.
The drivers side window will not roll up using the master switch on the drivers side. I replaced the switch with one I bought online and it worked for one day then stopped working again.
The bottom of the master switch seems to be getting hot so I figured there was something wrong with the window regulator.
So I tore off the door panel and pulled the window motor/regulator out.
Turns out that when I plug in the switch and turn the key to the on position, the window motor is constantly stuck in "up mode". If I push down on the switch it stops rolling up but when I let off it resumes trying to roll up again.
Same thing with rolling it down in "Auto mode". If I push down for "auto mode" it stops the window from rolling down for about 5 seconds and then resumes trying to roll itself up again..
I ordered a new switch again and as soon as I plugged it in it started smoking and would not work at all. I tested the Motor/Regulator and there did not seem to be any shorts or problems.
I just got a replacement switch in the mail today but I am reluctant to try installing it because I don't want to burn up another new switch.
Also I did check for broken wires inside the door and also between the door and the body of the truck. Everything seems fine..
What do you guys think.. Bad switches from China? Or is there something else I am missing?
Any help would be greatly appreciated.
Old Feb 18, 2015 | 08:17 PM
steve(ill)'s Avatar
steve(ill)
when the window travels full stroke is needs to "stop" at the end. Normally that is some type of torque switch attached to the motor or linkage, not the door switch... I cant say for sure, but I would look closer at the motor and what "kicks it out" when you torque out at full travel.
Old Feb 19, 2015 | 06:49 AM
shorod's Avatar
shorod
While there is a circuit breaker inside the power window motor that should momentarily stop the window movement when it either comes against an obstacle or hits the end of travel, that is only intended as a temporary stop. The power window switch also needs to be released to eliminate the flow of current to the motor. Otherwise, as soon as the thermal breaker in the motor resets, the window will once again attempt to move. In the normal "off" position, both leads from the window switch to the motor should be at ground potential.
Where things differ a bit on the driver's window is because it has the one-touch down feature, there are some electronics that keep power to the driver's window motor until the switch is either pressed again or until the thermal breaker stops the current flow to the motor. It sounds like what's happening here is the electronics for the driver's door motor are continuously sending power and ground to the motor and once the thermal breaker resets, it gets power again to raise the window.
If you have a multimeter or test light you can confirm this by unplugging the motor at the regulator/motor and measuring across the terminals. If the test light lights or the meter shows battery voltage, there is an issue between the regulator and the power being provided to the master switch assembly. Since the new switch started smoking and wouldn't work, that makes me suspect the issue might actually be with the wiring rather than the switch since the one touch electronics are supposed to be in the switch assembly. Either that or you have bad luck and your new switch was defective as well. Have you carefully inspected the wiring between the switch and the regulator for any signs of modification?
-Rod
Old Feb 20, 2015 | 12:37 PM
weross67's Avatar
weross67
Arrow Master Switch
Based on your description of the problem I feel the Master Window Adjust Switch is defective Part Number: 14529(SW-7142). The testing of this device is very limited and for most part if you knew what was wrong with it there is nothing you can do. A new switch from Ford will run from $150 to $189 or less I would be caucus of trying to use a after market switch. All the control and functions come from this switch for the Driver Side window there are no external feedbacks just the power to the motor. The electronics in this module also controls the common to the other doors so miss wiring on the other doors can cause problems with this Switch.
Last edited by weross67; Feb 20, 2015 at 12:58 PM. Reason: Left out important imformation
Old Feb 20, 2015 | 01:20 PM
weross67's Avatar
weross67
You can unplug connector C504b from the switch and the front windows should continue operating this will eliminate part of the wiring.
2.7EcoBoost
2015 - 2020 F150
Aug 5, 2019 11:12 AM
2002f250xlt
May 31, 2017 11:28 AM
AKHunter93
Aug 7, 2016 02:30 PM
psheridan
2004 - 2008 F150
Jun 24, 2013 06:14 PM
Taboo
Jul 24, 2007 12:24 PM
