Rain guards/window visors
Old May 21, 2019 | 11:30 AM
  #31
orion1968's Avatar
orion1968
I have always had good experiences on all of my vehicles with the in channel weathertech in the last 15 years. I did have one fall off of a rear window in may Saab but they replaced it free. The key is reading the directions, including the fine print., The rears I just installed have clips now to help them along with the 3m tape. The key is the temperature. If directions are not followed they will not stick correctly. Also they need to be left in place with the windows up for several warm days then you will not have issues with the auto sensors.
Old May 23, 2019 | 11:06 PM
  #32
Smirks90's Avatar
Smirks90
Weather tech
Old May 24, 2019 | 06:11 PM
  #33
MrOneEyedBoh's Avatar
MrOneEyedBoh
Id guess and assume so, but the in channels will scratch the edge of the windows, right? Seems inevitable since its wedging into the channel with the visor.
Old May 24, 2019 | 08:00 PM
  #34
cficare's Avatar
cficare
Which is the harder material, glass or plastic? Unless you've had some sort of coating applied to the exterior surface of the glass, I doubt the glass would ever suffer from scratches. We have had the in-channel visors on several vehicles with no ill effects. Though my '17 KR does not have them, we do have them on my wife's '18 Explorer LTD. As mentioned above, one trick is to let them soak in direct sunlight, plus ... as was the case with the '18 Explo ... ensure the double-back tape is positioned in the appropriate locations. I did have a few issues fitting the '18 Explo visors versus the exact same visors I installed on her former '13 Explo LTD.
MontanaboyDesigns
Aug 15, 2016 10:05 AM
351Cleveland C4
Sep 18, 2013 10:02 PM
Pitcrw6
15
Dec 7, 2011 08:26 PM
dnorris80
2004 - 2008 F150
13
Apr 4, 2008 03:04 PM
bucks77ford
17
Nov 27, 2007 06:09 AM
