Proportioning valve help
Old Oct 31, 2018 | 02:06 AM
Sparty73's Avatar
Sparty73
I’m in the midst of a Centech rewire. When I got to the proportioning ( pressure diff ) valve the plug that connects to the switch was pretty much unusable and frayed. I’ve been searching and it seems impossible to find this plug. It’s a 2 prog plug that mates to the switch. Every search I’ve done I’ve only come across single prong plugs. Anyone have a line of theses plugs. If not could I swap out the switch to a single prong version ( I saw one on jegs). Any help would be appreciated
sean
Old Oct 31, 2018 | 07:42 AM
VitaminC's Avatar
VitaminC
I think you can use two spade connectors and make your own.
Old Oct 31, 2018 | 08:46 AM
mark a.'s Avatar
mark a.
Local junk yard ?
Old Oct 31, 2018 | 01:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The brake pressure differential valve warning lamp switch (C8AZ-2B264-A) is the same: 1968/69 FoMoCo Passenger Cars; 1968/79 F100/350, Bronco & Econoline.
spidermantat
Dec 16, 2013 05:22 PM
thomabb
Jan 31, 2012 01:21 PM
Robert6401
15
Jun 26, 2009 04:59 PM
300-6
Jul 29, 2006 04:42 PM
rockslut
Apr 12, 2006 10:02 PM
