Inertia Switch Bypass
Old Jun 26, 2006 | 01:02 PM
300-6's Avatar
300-6
Okay, 87 F150 4x4 4.9l
Can the Inertia switch be Bypassed, Or Jumped.
Old Jun 26, 2006 | 01:38 PM
GLR's Avatar
GLR
On demo cars we just twist the 2 wires together after cutting off the plug. If you don't want to cut the plug off, you can use a jumper in the plug and tape it up.
Old Jun 26, 2006 | 02:18 PM
300-6's Avatar
300-6
That is what I going to do, but I am wondering if their could be any problems.
Old Jun 26, 2006 | 02:22 PM
monsterbaby's Avatar
monsterbaby
not unless you get into a serious wreck that breaks the fuel line, starts a fire and you don't turn off the ignition switch so the pump just keeps feeding gas to the fire.
Old Jun 26, 2006 | 04:21 PM
300-6's Avatar
300-6
In that case I am going to cut and twist, and call it a day,
Old Jul 29, 2006 | 04:42 PM
ClydeSDale's Avatar
ClydeSDale
I added a cut-off switch to my inertia circuit. Carb Guy said that since I don't drive Clyde a lot the bowl would dry out an leave varnish. He recommended running it dry or manually draining the primary bowl before leaving it idle (as in unused) for any length of time. I now shut off the switch and let it run out of fuel as I park it. Can also be used as an anti-theft device if the switch is hidden like mine is.
Roger
97-psd
Feb 26, 2016 09:05 PM
dogg16
Bronco II
Sep 20, 2011 10:08 AM
dayday
1997 - 2003 F150
Nov 16, 2010 05:39 PM
cbjr61
Aug 3, 2005 01:43 PM
sailboat2323
1978 - 1996 Big Bronco
Aug 26, 2003 11:09 PM
