head light switch ??
Old Apr 12, 2006 | 11:07 AM
rockslut's Avatar
rockslut
my head lights started blinking even wile not driving . so i switched out the switch with a new one. now my head lights seem to work but all the tail and running lights dont work at all. are these switchs sometimes bad? i remember a thead about this same thing but i couldnt find it when i searched. any ideas??
Old Apr 12, 2006 | 12:41 PM
3rdshiftzombie's Avatar
3rdshiftzombie
Exclamation lights
I had this problem with my van and replaced the switch,still had the problem so I returned the switch and purchased yet another but of a different brand,still had the same problem.I did some checking and found the original switch had shorted and damaged the plug or terminal some people call it, on the wire harness,the plug that the headlight switch connects to.Pull the switch again and look at the plug to see if it has signs of melting or other damage.I had to splice in another plug and the new switch worked fine,no problems now.You will need to make a trip to the scrap yard to get the plug you need but it's fairly easy.Good luck.
Old Apr 12, 2006 | 12:52 PM
Mil1ion's Avatar
Mil1ion
To answer your question : Yes, NEW does not make it GOOD.
Buy a Motorcraft switch.
http://www.motorcraft.com/default.jsp
Old Apr 12, 2006 | 01:04 PM
rockslut's Avatar
rockslut
no melt down on plug that i can see. i will try a motercraft switch and go from there. thanks for the help!!
Old Apr 12, 2006 | 03:14 PM
73Custom's Avatar
73Custom
I had a similar problem with my '73. Lights were blinking, and new switch didn't change it. I found that the wiring near the rear bumper was shorting to the frame. Right ahead of the bumper, the taillight wiring goes through a hole in the crossmember, it had rubbed through and was shorting. Repaired the wire, covered it with rubber hose and all is fine.
Marty
Old Apr 12, 2006 | 10:02 PM
rockslut's Avatar
rockslut
thanks for all the help guys . i found the problem it was also a frayed wire shorting out this kind of stuff drives ya crazy, but it worked out wile looking for the prob i fixed a couple other things that were not working dome light dash lights and fuel sending thanks again!!
