Sponsored by: Real Truck
Remote Start Woes
Old Oct 22, 2018 | 07:58 AM
dmorrill22's Avatar
dmorrill22
Remote Start Woes
I just installed a 100 series remote start kit on my 2012 F250. I have changed the settings in the dash screen to allow for remote start, and changed the settings in the BCM to enable remote start as well. I had the key cut and programmed it to the truck with FORScan, and it works fine. However, when I try to remote start the truck, I get one horn honk and two flashes of the parking lights. No attempt to start or anything. I have read that this may be an issue with the hood switch, so I took a look and bent the tab up and made sure it was getting closed by the hood. No errors on the BCM or PCM. I have read this kit should be compatible with these Super Duties, so what gives???
Thanks.
Old Oct 22, 2018 | 08:47 AM
Colorado350's Avatar
Colorado350
I’d give the manufacturer a call and talk to a technician, probably something simple. Good luck
Old Oct 22, 2018 | 11:35 AM
Just Strokin's Avatar
Just Strokin
Are there any DTC's stored by the PCM/ECU? If so, it will not remote start. Clear them and try the remote start.
From the 2015 Super Duty Owner's Manual
The remote start system will not work if:
• the ignition is on
• the alarm system is triggered
• you disable the feature
• the hood is open
• the transmission is not in P
• the vehicle battery voltage is too low
• the service engine soon indicator is on.
Old Oct 22, 2018 | 11:37 AM
dmorrill22's Avatar
dmorrill22
No DTCs at all. I had to do a PCM relearn to get rid of a P160 code a while ago, but after that I had no remaining DTCs on any module. Battery voltage was fine too.
Edit: Just to clarify, my adapter has both HS and MS-CAN capabilities, and it is not finding any faults on modules with FORScan.
Old Oct 22, 2018 | 03:08 PM
Just Strokin
did you use the key to start the truck after the horn honk and flashes and then try the remote start again?
Old Oct 22, 2018 | 03:15 PM
dmorrill22's Avatar
dmorrill22
I've tried it a few times and it still does the same.
Old Oct 22, 2018 | 04:35 PM
Just Strokin
Read what Pocket/Curtis wrote on this thread. If you can't solve the problem, send Pocket a PM and he might can send you more info.
https://www.ford-trucks.com/forums/1...l#post17734210
by chance, did you try short across the hood switch connector to see if the switch is the problem? How much fuel is in the tank?
Old Oct 23, 2018 | 08:06 AM
dmorrill22's Avatar
dmorrill22
Fixed! Thank you sir. I had opened the hood and cleaned the switch connection and manually held down the switch still no luck. spliced the wires together, and it works!!
96_F250_Deezal
Feb 5, 2018 07:08 AM
Steve White
Dec 18, 2017 10:14 AM
dmorrill22
Jan 10, 2017 12:34 PM
jhaines10
6.7L Power Stroke Diesel
Jun 29, 2016 08:36 PM
PowerStrokeHD
25
Jan 28, 2013 06:54 PM
