E4OD missing filter, moves forward in all gear selections
Old Oct 16, 2018 | 06:38 PM
LJForrist's Avatar
LJForrist
Hi everyone, I posted this in the 87-96 pickup forum but thought you all might have the info. I picked up a 96 F150 5.8, E4OD 4x4 from a guy off craigslist. They had torn up the original transmission and had someone put in transmission out of another truck that was supposed to have been good. After install with new torq converter, the thing wants to move forward all the time. In park it comes against the pall, in reverse it just acts likes its bound up and won’t move and in ND21 it goes forward. Enter me, a few hundred buck and I drag it home. My assumption is that the forward drive clutch is welded together. I crawled under it today to start removal of the transmissision and when I pulled the pan to drain the fluid, there was no filter in there. It is my unterstanding that the filter acts like a pickup tube so the thing had to be starving for oil. Now I’m sitting here scratching my head wondering if the symptoms could be caused by just missing a filter. Does anyone have any ideas as to what a tranny would act like with no filter in there? Is there any potential for the thing to want to move forward in neutral and park because it wasn’t pumping oil?
let me know if you have any input or additional questions for me. Thanks
Old Oct 16, 2018 | 07:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If it wasn't pumping oil no clutches would engage and it would be in neutral in every position. It obviously was pumping fluid, but the forward clutch isn't releasing. Usually, that means the clutch has welded itself together. It could also mean that the linkage isn't connected properly so that the trans is in forward no matter where the shift lever is placed.
Old Oct 21, 2018 | 09:39 PM
LJForrist's Avatar
LJForrist
I got the transmission out and apart today. It was as expected. The forward clutch was severely burned and siezed together. Also I'm sure by the gunk in the bottom of the pan that the so called good replacement wasn't as great as the previous owner thought. I guess there are no short cuts.
LJForrist
Oct 21, 2018 09:42 PM
scott351wind
Jun 16, 2018 07:51 PM
95F150RLP
Jul 7, 2017 05:00 PM
econobug
Mar 4, 2012 05:39 AM
muff
Jun 25, 2010 09:38 PM
