Wacky Tachometer
Old Oct 12, 2018 | 07:44 PM
akblackfoot's Avatar
akblackfoot
Wacky Tachometer
Today my tach started acting up. It won’t go below around 2000 when off and starts from there as if it’s zero. Torque Pro monitor is showing correct. Is there a fix besides the whole cluster?
Old Oct 13, 2018 | 01:01 AM
87crewdually's Avatar
87crewdually
Not sure what year you're working on but with Key Off, hold down the odometer reset button. Then while holding the reset, turn key on but don't start it. This will put the cluster in test mode and then you can let go of the reset. It should then sweep all the gauge needles and reset them to where they should be. Cycle the key and see if its reset.
Old Oct 13, 2018 | 01:28 AM
akblackfoot
Thanks!! Mine actually has the info center or whatever it’s called so I had to hold the reset and info buttons, but it worked.
Old Oct 13, 2018 | 12:50 PM
87crewdually
Great! While you're in that test mode you can toggle through and see other parameters that the pcm is seeing. If you didn't have a scanner and were trying to diagnose something, it could come in handy.
Old Oct 13, 2018 | 01:34 PM
Yahiko's Avatar
Yahiko
Sometimes the little spiders will build a web that hangs up the needles.
It the test mode dos not fix it give https://circuitboardmedics.com
a call for a rebuild. They are a FTE sponsor and will get things working.
redsplashman
2004 - 2008 F150
Dec 24, 2010 06:33 AM
smoke14
1997 - 2003 F150
Oct 23, 2009 08:52 PM
scatgo
Jul 21, 2008 04:40 PM
WVF150VIANC
2004 - 2008 F150
Aug 17, 2006 08:20 AM
Brian460
Oct 2, 2005 07:45 PM
