A strange one
Old Jul 21, 2008 | 04:14 PM
scatgo's Avatar
scatgo
A strange one
When I turned the key on the 96 350 we have at work I saw the speedo go from 0 to max then drop back down to 0 and the odometer read E 08 3.
When the WTS light went out I started it and the same thing happened the speedo maxed and dropped to 0 and the odometer read E 08 3. While driving the speedometer stayed at 0 and when I hit the select button that would switch to trip meter the odometer read 111111 then when I hit it again it went to 222222 then 333333 and so on. All other gages seemed to work fine. This happened every time I started the truck then while driving I hit the set button that would set the trip meter to 0 a bunch of times and every thing went to normal and it looks like the miles I added while it was acting up were added. What was all that about??????????????
Old Jul 21, 2008 | 04:29 PM
Cuda_jim's Avatar
Cuda_jim
Someone pushed all the right buttons to do an instrument cluster check...stop messing with the buttons....
This is for a 2003..not sure if our trucks are the same:
Instrument Cluster Dealer Test Mode
To enter the Instrument Cluster Dealer Test Mode, depress and hold the instrument cluster SELECT/RESET button and then turn the ignition switch to the RUN position. Continue pressing the SELECT/RESET button (five seconds) until tESt is displayed in the odometer. The SELECT/RESET button must be released within three seconds of the odometer displaying tESt to begin the dealer test mode. Depress the SELECT/RESET button to advance through the following steps until dtc is displayed. Depressing the SELECT/RESET button will display any continuous DTCs stored before proceeding to the next step.
Old Jul 21, 2008 | 04:32 PM
Hussler's Avatar
Hussler
You got into the programming mode to change the speedo to match tire sizes. The 3 in the E 08 3 indicates it has been programmed 3 times .. starts at 6 then counts down. Once at 0 it no longer can be programmed. I can't remember for sure but it's something like hold down the reset and turn key to run get you into that mode so maybe it's stuck.
Old Jul 21, 2008 | 04:39 PM
Cuda_jim's Avatar
Cuda_jim
Here's something that may be more useful:
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
Old Jul 21, 2008 | 04:40 PM
scatgo's Avatar
scatgo
OOOPS! I was just trying to set the tripmeter to 0 because I am looking into mileage.
Looks like I just stumbled into this. So far it looks like this truck only gets 9 MPG! It has a dump on the back and gets nothing but city driving. Never have too much weight in the back. Maybe 4 to 500 pounds. What do you think of the MPG?
