Sounds like a dud injector to me. This is where it would be nice to have a breakout box to isolate the bad stick. Saying that, it never hurts to hot-torque the injectors - because you can see the engine run with the covers off, and watch for a problem oil flow from one of the injectors.
I'm in the injector camp as well. I would do a CCT, and pull an oil sample. If the oil sample looks metalic, there's no need to waste postage sending it to the lab.
welp, ended up being an injector, or at least fuel.
i was on the fuel light when i took the above videos. got progressively worse (could even hear the fuel pump aerating KOEO) but went away entirely when i filled up the tank. suspect i have a broken/clogged pickup tube. guess its time to drop the tank and poke around.
