Mine has a 38k mile Spicer 5 speed. I know there is a lot of linkages between the shifter in the cab and the transmission and so far what little I've had the chance to check out, it all seems to be in good shape. Even so the shifter is stiff. Reverse actually touches the dash while finding 4th gear almost required me to scoot to the right.
I know these things have a reputation for being challenging to shift, but this is the first truck I've been in that made me wish I had longer arms. I'm not above adjusting the linkage or torching the shifter and bending it my way a bit if this is normal. Before I do anything rash I thought I'd post here first and see if this is normal.
If the rain will hold off for a few minutes tomorrow I'm planning to tackle some basic maintenance and dig deeper into the shifter. Any suggestions or resources would be greatly welcome.
If it finds and goes into each gear, regardless of shifter position or travel, I would leave it alone. Bend the shifter, but don't fool with that shaft, u-joints etc. JMO
Sounds like the linkage is worn. Lever hitting the dash in reverse was common. Lubing the linkage is always a good idea (check the manual, there are a number of zerk fittings). Should loosen it up, but won't do anything for the long throw. If it goes into all the gears, I wouldn't mess with it.
I liked these trucks a lot better if they had Allison transmissions!
I just might take you up on that. I've not had a chance to do much with it due to work but I hope to have some time off/better weather soon.
You wouldn't happen to have a tach cable or an instrument cluster would you?
Should have everything but the exhaust manifolds. Have them sold.
Former fire truck with 18k miles, I was putting a spreader bed on it when a valve head broke damaging a piston and cracking the cylinder wall.
Bought another truck cheaper than I could fix the 534 engine, has a good solid cab, good seat, I have a new uninstalled pto unit for the Spicer trans.
