Torque Pro Assistance and ideas?
#46
I agree 100% on the beer! I also agree about knowing what my foot is doing, but for the sake of the public viewing a log, I think the throttle position would be nice to compare against the other parameters.
Also, if the throttle position was identifiable while using cruise control to see how hard the pcm is pushing to keep the truck up to speed, I could find a learning opportunity in there.
I did get throttle position to work, but it reads zero with cruise control on.
Either way, Forscan and Forscan Lite are the better tools to have regarding DTC's and tests.
#47
Yes, that is correct as was eluded to above. I will be monitoring MFD instead of throttle position in an effort to see how much fuel the PCM is calling for when the truck is using cruise control. I think that when I am towing heavy and if the cruise control is going from say 35%-100% throttle when climbing a rolling hill or slight incline I will probably stop using cruise control in those situations and use my right foot. This might increase my MPG's from 13 when towing. If not, then the PCM can do whatever it wants.
#48
on
Yup, screw TP...
I have given up trying to get IAT and MAT to work on my phone. I will try to get them to work on the tablet when it comes in the mail tomorrow, but am not holding my breath.
If I cannot get them to work, I will log the IAT and MAT from Forscan Lite for data collection and review purposes.
#49
I am using the paid/pro version. I am going to start another thread for the IAT and MAT specifically to come PID entries. I wish I had thought of a piece of software that I could sell to millions of people and it only work half the time, then not work at all and then they figure out how to fix it...
#51
I went and checked just because I was curious and just because you have always stepped up and helped me out on a lot of stuff. The only difference I see is that in my setup I have "unit type C" wheas you have "unit type F" but in my TP settings I unchecked "Celsius" as you did, and mine reads in Fahrenheit. If you look at my TFT it also reads in F although is says "C" on the gauge. So maybe that would do it, or try a different gauge style.
Tugly
186
11-09-2020 07:47 AM
Sous
31
08-25-2018 10:01 AM
20powerstroke02
07-25-2016 07:23 PM
