Compressor Wheel Nicks
Old Jul 6, 2018 | 07:41 AM
ToddMyers58's Avatar
ToddMyers58
I just recently pulled off the intake on my 01 f250 and noticed that the compressor wheel has small nicks on almost all the fins. It is the stock turbo with 138k on it. There is no shaft play at all as well. My question is what would cause this? There was a small amount of very fine dust in the the take stuck on oil from the CCV. Would surge cause this sort of thing?
Just wondering what the best thing to do is.
Thanks for any advice
Old Jul 6, 2018 | 07:53 AM
Dan V's Avatar
Dan V
When you installed the 6637 air filter, did you notice anything?
Old Jul 6, 2018 | 07:56 AM
ToddMyers58
I did not notice anything when I first installed the filter but I did not take a very close look, there may have been some of the smaller nicks but the few larger ones seem somewhat new.
Old Jul 6, 2018 | 05:42 PM
coax9952's Avatar
coax9952
That Wheel is Dusted, and I would bet that it's been that way for quite a while. A leaky filter Box w/ irregular filter changes, Cheap Filters.... any of the above....You needs a New one.
Old Jul 6, 2018 | 06:34 PM
Silverhks's Avatar
Silverhks
I would check/replace your filter. Also check your intake pipe to make sure it doesn't have a hole. Then make sure the clamps are tight on reinstallation.
I doubt whatever did that came from inside the engine or you would have more evidence...
Old Jul 6, 2018 | 07:12 PM
Handy1's Avatar
Handy1
There is one other thing that will cause this kind of damage to a compressor wheel. It's water. Water will cause this very fast,but is not likely as far as I know in this application. I see this all the time on industrial air compressors. They use the same type of compressor wheel. They have water cooled intercooler to cool compressor air and when they get a hole in the intercooler ,the water trashes the wheel.
Old Jul 7, 2018 | 10:04 AM
timmyboy76's Avatar
timmyboy76
How can anything from within the engine, wipe out or even disrupt the wheel thats inline with the air intake? ..AND, if possible, what other evidence would there be...a loss of blinker fluid
Old Jul 7, 2018 | 07:27 PM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
Well the good news is from what I've read, pulling the turbo on the super duty is pretty easy, compared to the OBS. I've only done it on an OBS. Worst job I've ever done by far. But, I'd replace this wheel and change your filter.
Old Jul 7, 2018 | 11:45 PM
'88 E-350's Avatar
'88 E-350
Leak in the filter or ducts let stuff in. Stuff got in the filter/ducts when last working on it. Damaged bits of the ducts broke free; possibly shaved some rubber off when fitting the 6637. Something came up through the CCV.
It doesn't appear dusty so it's unlikely to be a leak, I also can't imagine any chunks of stuff coming from the CCV. My guess would be something got in there when you last had it apart or you damaged the rubber hose when fitting the 6637 and a chunk of rubber did it.
mrm8174
Apr 26, 2015 08:06 PM
Joey Fletcher
15
Sep 19, 2013 07:32 PM
bigpowerstroke
Jan 15, 2010 12:00 AM
CheaperJeeper
13
Mar 16, 2008 05:39 AM
Ford79
Nov 15, 2006 08:50 PM
