Changing differential fluid
Old Jun 12, 2018 | 04:19 PM
F0rdF0rever's Avatar
F0rdF0rever
Just picked up the mobile 75w140 for my diff. It's says it contains friction modifier. Should I add other ford additive to it anyway?
Old Jun 12, 2018 | 04:32 PM
bismic's Avatar
bismic
I don"t .
Old Jun 12, 2018 | 06:57 PM
DSMMH's Avatar
DSMMH
Agree with Mark. If the diff fluid is synthetic, then I would not add the Ford friction modifier. Now having said that, I have 6 quarts of Royal Purple 75W-140 synthetic (I have a large diff cover) diff fluid in my diff and 10oz. of Archoil 9100 friction modifier. With so much rain, not hard to check my diff for proper operation. Works great.
Ed
Old Jun 12, 2018 | 08:15 PM
F0rdF0rever
Filled it up without the additive. Thanks guys.
Old Jun 12, 2018 | 09:05 PM
FiznUKa's Avatar
FiznUKa
Is your diff a limited slip?
Old Jun 13, 2018 | 06:03 AM
Yahiko's Avatar
Yahiko
When I changed mine on the old truck it was with Mobil1
and going around corners it would make noise. So it got
a little bit added at a time until is stopped making noise.
Old Jun 13, 2018 | 06:15 AM
bismic's Avatar
bismic
I would certainly do the same (adding the extra friction modifier), but mine has never made noise. Right or wrong, I have been using that fluid without extra friction modifier for 150k miles.
Old Jun 13, 2018 | 06:20 AM
Yahiko's Avatar
Yahiko
It should work without it but I was told that in some cases the clutch pack is a bit tighter and just needs a bit extra.
Old Jun 13, 2018 | 06:59 AM
bismic's Avatar
bismic
Good to know. Thanks!
01raptor
Jul 1, 2011 09:19 AM
Dyllan78
Jan 30, 2011 07:59 PM
crimsontide
Jan 21, 2005 11:45 AM
droff
1997 - 2003 F150
Apr 6, 2004 10:44 PM
