rear diff fluid
Old Jun 30, 2011 | 09:05 PM
01raptor's Avatar
01raptor
rear diff fluid
I have a 02 f250 ext short box. I noticed today I was low on rear diff fluid. What type of fluid should I add. It is something I can get at walmart. Thanks
Old Jun 30, 2011 | 09:37 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Should be 75/140 Synthetic, Do you have limited slip?
Old Jun 30, 2011 | 09:41 PM
clintbonnie's Avatar
clintbonnie
https://www.ford-trucks.com/forums/9...for-diffs.html
Old Jun 30, 2011 | 09:58 PM
RainStroked's Avatar
RainStroked
I just used the Mobil 1 synthetic 75w-140 in my 99, it has the LSD additive already in the fluid and it's been good to go in mine. I believe Walmart carries that, but any other auto parts store will have it. Make absolutely sure it's synthetic 75w-140, there's a tag on the diff that states synthetic fluid only.
Old Jun 30, 2011 | 11:45 PM
01raptor's Avatar
01raptor
im not sure if i have limited slip. truck is fairley new to me. Would supertech fully synthetic 75w-140 work? since im just toppping it off with a little.
Old Jul 1, 2011 | 12:17 AM
BigAlsPSD's Avatar
BigAlsPSD
You will likely have to look at the tag on the cover to find out if it is LS, but the supertech is just fine to use. If it rumbles a little when turning pick up some LS additive and add a little at a time till it doesnt any more.
Old Jul 1, 2011 | 12:36 AM
01raptor's Avatar
01raptor
hopefully i can still read the tag. So if it doesnt say limited slip then i dont have to worry about the additive? If it does maybe ill look for some 75/140 with the additive in it.
Old Jul 1, 2011 | 01:44 AM
RainStroked
I think a lot of them have LS, especially if it's a 4x4 "Off-road" or FX4. If you don't have LS then you won't need to worry about additive, but I do think a lot of synthetics come with the additive blended in.
Old Jul 1, 2011 | 08:01 AM
snakedoc's Avatar
snakedoc
the door tag will say what it has if you cant read the rear tag.
Old Jul 1, 2011 | 08:27 AM
mueckster's Avatar
mueckster
x2 on the Mobil 1
My truck has the Offroad Pkg, but didn't come with a LS rear diff. I upgraded to a Tru Trac, which doesn't require the additive also.
Old Jul 1, 2011 | 09:19 AM
01raptor's Avatar
01raptor
i just have 4x4 no off road package or anything. i could only read one tag on the diff it said to only use 75/140 synthetic. i looked on the door and by i didnt see anything that had ls by it. just k/31/9 by the axle part of the sticker. so im assuming i dont have have limited slip?
texasJ
2004 - 2008 F150
Sep 3, 2014 06:19 AM
diesel7.3power
Aug 31, 2011 06:59 PM
brian931
1983 - 2012 Ranger & B-Series
Apr 8, 2009 07:16 AM
Rich in CO
1997 - 2003 F150
Nov 13, 2006 07:24 PM
dansV10
Nov 16, 2005 12:49 AM
