PMGR starter
Old May 8, 2018 | 07:12 AM
  #31
Gigemags05's Avatar
Gigemags05
Yeah I will take it off of the S lug. But instead of going to the B+ like shown (along with 30 amp breaker), I need to find another switched wire from the fuse block?
Old May 8, 2018 | 08:07 AM
  #32
FuzzFace2's Avatar
FuzzFace2
Don't move the B+ for the fan.
For relay to work it has to have 12v power that B+.
You need a ground
You need a wire from relay to what ever you are powering (fan).
and you need a wire to tell the relay to close and send power to the fan, known as the switch wire.
I believe you are putting the switch wire on the S lug and the only time it will tell the relay to close sending power to the fan is when you try and start the motor, no other time.
I also believe that switch wire is back feeding power to the S lug keeping the starter solenoid closed sending power to your starter.
Or that other power wire is and why it should be removed too.
Dave - - - -
Old May 8, 2018 | 08:19 AM
  #33
FuzzFace2's Avatar
FuzzFace2
I just rechecked your fan wire drawing I don't know just what that yellow wire is for but looks to be not needed. Or is it the ground?
It looks like you have the switch wire to the temp sender so the fan will turn on when it reaches a set temp and that is good.
power side and fan side looks good too so I don't see a ground.
The relay should have numbers next to each lug can you list the number and what wires are connected to them that will help on how the relay gets wired.
Dave - - - -
Old May 8, 2018 | 08:49 AM
  #34
Gigemags05's Avatar
Gigemags05
You need a ground
Dave - - - -
The wire that was going to the S lug was the red wire in the diagram that is supposed to go to a 12v source. It wasn't what was backfeeding, that was the "solenoid power" wire that we now know is not needed. I will also move the red wire to the B+ so that there is a constant 12v on the fan relay.There is a switched source coming from fuse block into the fan relay, that's the yellow wire in the diagram. There is also a wire going to the fan from the relay, and there is a wire going to the thermostat from the relay, both just like in the above diagram. The wire going to the thermostat has a ground coming off of it as well. The relay came pigtailed that way.
Old May 8, 2018 | 11:31 PM
  #35
4x484150's Avatar
4x484150
What is the reasoning for wiring the PMGR starter to the opposite terminal on the starter solenoid? How does that not keep the starter from going non stop? Last night I touched the battery cable to the battery out of curiosity and the starter immediately started. I don't have the ignition switch wired up yet, so I assume that this condition won't be an issue when I wire the ignition up. I am moreso just curious of how it works.
I installed my PMGR starter exactly as this picture states, works great. When I get home in about a week, I will post pictures here of my setup
ArtsBest
Electrical Systems/Wiring
Oct 9, 2008 01:20 PM
78'Ranger
Aug 26, 2007 08:14 PM
cjf5150
31
Mar 17, 2006 05:47 PM
4.9inline6
Feb 23, 2006 07:52 PM
blatherskite
Dec 19, 2005 08:34 AM
