Mini starter wiring??
Old Dec 14, 2005 | 11:23 AM
blatherskite's Avatar
blatherskite
Is anyone else using a Ford mini starter (required with 'tight fit' or 'block hugger' headers) that has a solenoid on the starter in a truck that also has the 'old style' fire wall mounted solenoid??
If so, I could use some help with how to wire that setup. I did it the same way I used to wire my 'non-ford' stock cars that had the starter mounted solenoid but it doesn't seem to work the same with the ford starters - I've had three starter solenoids go bad......
Thanks for any help!!
Old Dec 14, 2005 | 11:48 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I recently wired my 56 with components like you describe, but it is in a storage unit 750 miles from here. Once I get relocated and the PC reconnected, I can scan the wiring diagram that came with the Ford Motorsport starter. I seem to remember that one wire goes from the battery to the starter relay and then from that terminal to the starter solenoid. The opposite starter relay terminal goes to the solenoid small connector. The starter cable is hot all the time and only when the signal goes from the relay to the solenoid does the starter engage. I know, not a good enough description, but I can't access my wiring diagrams for until around the end of next month.
Old Dec 14, 2005 | 12:06 PM
Happyford's Avatar
Happyford
I recently in stalled one on my 351W. main(positive) cable to the large stud and start wire from ignition switch to solenoid. I'm using MSD6 ignition, so mine is real easy.
Old Dec 16, 2005 | 10:16 PM
55FordLover's Avatar
55FordLover
Hey man,
Wire everything through the started solenoid...its easy and on the net...i will look at mines tonight and post what i have in my 54...
James
Old Dec 17, 2005 | 09:34 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If I understand your question correctly, here is what I did.
Use the starter contact on the ignition switch to trigger the stock Ford starter solenoid (on the firewall).
Connect both the heavy starter main feed and the starter solenoid wire to the outlet post of the Ford solenoid.
This may seem kind of backwards, but it works fine on mine. It is the least disruptive of the stock wiring, too.
Old Dec 19, 2005 | 08:34 AM
blatherskite
That's how I had it wired but the starters (three so far) keep 'breaking' after several uses. (they just spin freely and won't turn the engine over). If I bench test them, the gear is popping out but they won't turn the engine over.
andyofne
24
Oct 9, 2016 02:58 PM
AtlM5
Dec 13, 2015 07:57 PM
Sawyerjosh
Sep 17, 2015 11:22 AM
gooldg
Jun 14, 2015 12:34 PM
Ryan Weaver
Jan 4, 2015 04:30 PM
