Sponsored by: Real Truck
Blown Engine
Old Apr 25, 2018 | 11:19 AM
mtnhome's Avatar
mtnhome
Exclamation Blown Engine
Has anyone experienced a blown engine on an E-450 Triton V10 6.8l engine. I have just over 23K miles on my 2013 Coachmen Leprechaun 319ds motorhome and my engine needs replaced. I would appreciate feedback from anyone on this.
Old Apr 25, 2018 | 11:25 AM
ford390gashog's Avatar
ford390gashog
Nope, that's a very solid engine platform. But they have been known to occasionally break a lash adjuster and eat a valve. What is the engine doing ?
Old Apr 25, 2018 | 11:30 AM
David7.3's Avatar
David7.3
Agree with Gashog, that is a stable platform that has been used by Ford for many years. The 4.6, 5.4 are proven platforms. they have there problems but blown engines at that low mileage is a concern. Did she have regular service? Overheated?
Old Apr 25, 2018 | 12:05 PM
mtnhome's Avatar
mtnhome
The motorhome was towed to a Ford dealer and they did a diagnostic on it. They said that it was shot and ordered a long block to replace it. Just had the oil changed a week before this happened, and before that there was regular service performed. It never overheated. I was driving back to Denver, from Green Valley, AZ on I-25. I heard a clacking sound, looked down at my guage's and the oil indicator dropped and the oil light came on. I immediately pulled off the highway.
Old Apr 25, 2018 | 01:26 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
There was that one thread on 2013 V10s with oil problems, I think he got to the point he blamed a bad gasket on the timing chain tensioner on one side, it was leaking enough to reduce oil pressure and the engines were dropping rocker arms:
Thread:
https://www.ford-trucks.com/forums/1...-failures.html
89 Posts in he got to the root cause:
https://www.ford-trucks.com/forums/s...8&postcount=89
https://www.ford-trucks.com/forums/s...8&postcount=90
https://www.ford-trucks.com/forums/1...l#post15866945
Old Apr 25, 2018 | 05:20 PM
finn's Avatar
finn
Was the failure at the bottom of a long downgrade? We’re you using the engine compression to slow the camper down?
Old Apr 25, 2018 | 05:24 PM
redford's Avatar
redford
FTE Leadership Emeritus
Can we get some specific details on the engine failure?
Old Apr 25, 2018 | 06:33 PM
DogRidesInBack's Avatar
DogRidesInBack
I'm thinking no oil, spun bearing. Assuming clacking equals clattering, so a dry valve train, followed by maybe one or two squeaks (a main or rod bearing).
Old Apr 25, 2018 | 07:16 PM
speakerfritz's Avatar
speakerfritz
What oil weight
what oil change interval
whats the weight of the rig?
Old Apr 26, 2018 | 06:59 AM
Djosbun's Avatar
Djosbun
I’ve heard horror stories on those quick lube oil change places screwing up, not enough oil, leaving old filter gasket on (two oil filter gaskets can lead to oil shooting out from between them). Check for leaks/small puddle at the last place you parked before she died.
— Dave
Med Sun
6.7L Power Stroke Diesel
30
May 12, 2014 02:03 PM
Voice23
Modular V8 (4.6L, 5.4L)
Dec 25, 2010 10:31 PM
recklesskerry
2004 - 2008 F150
Sep 2, 2010 10:47 PM
hotroddually
Jan 21, 2010 07:00 PM
