Sponsored by: Real Truck
Overloaded the payload today!
Old Apr 25, 2018 | 07:33 PM
Nick1987's Avatar
Nick1987
1st time hauling a load of gravel in the bed today, and I believe that I got real lucky. Truck doesn't seem to be making any sort of weird sounds or anything, nor did it while it was getting loaded down with 3 bucket loads while at the quarry (at least not that I could hear). From inside the cab, I could see that she had squated down a good bit, so as I was leaving the quarry, I crossed over the scales. A whopping 11,5xx lbs is what she weighed in at. Minus 6200 lbs with me in the truck, that made for a 5,300 lb payload. I don' want to ever do that again, but on the other hand, and although I'm kind of impressed, just glad nothing broke(knock on wood).
Has anyone here seen this before or perhaps have experienced it themselves?
Old Apr 25, 2018 | 07:42 PM
jetty's Avatar
jetty
Definitely a tad overloaded, GVWR maybe 9 or 10k..
That is what I like about these trucks, load em up and move em out, without a lot of white knuckles wrapped around the wheel. Very happy w/ the way my similar standard cab truck hauls, MUCH better than the '83 chev squarebody that it replaced.
Old Apr 25, 2018 | 07:46 PM
Swamp_Yankee's Avatar
Swamp_Yankee
The biggest limiting factors with payload are tires and brakes. Max load on those tires is 3,417lbs at max inflation (probably 80 psi), so theoretically you had about a 1,000lb margin of safety, but at highway speed your ability to stop in a reasonable distance would be severely impaired.
GVWR on my 2003 SRW Regular Cab F350 was 9,900 so I would guess that a 250 would be a bit less.
Old Apr 25, 2018 | 08:07 PM
Nick1987's Avatar
Nick1987
Sounds about right at 9,900 or so. I had about 60 psi in the rear and 55 in the front. Took the interstate about 55-60 mph for safety sake (stopping and manuevering). As far as brakes and stopping goes, that's why I was so happy to find a 6 speed manual. Made use of the engine braking ( if that' the proper terminology) in order to not burn up the brakes.
Old Apr 25, 2018 | 08:24 PM
seventyseven250's Avatar
seventyseven250
Pretty commonly done and as long as you are extra careful it's not that bad. Don't make a habit of it.
Old Apr 25, 2018 | 08:27 PM
Nick1987's Avatar
Nick1987
for sure, not ever again
Old Apr 25, 2018 | 08:54 PM
seventyseven250
Back when I was young(er) and dumb(er) I worked for one of those student junk hauling companies. We usually were carrying bulky stuff like furniture, so the trucks had really large dump boxes, but they were just standard F350 chassis cab trucks. Had someone loading bricks with a tractor one day and I wasn't paying attention. Ended up with four times more than what the boss said the max load was. Drove that through rush-hour traffic to the dump and managed not to rear-end anyone, which was probably more luck than skill.
Wish I had the scale ticket it was a ridiculous load.
Old Apr 25, 2018 | 09:17 PM
Nick1987's Avatar
Nick1987
bet that was a little nerve racking.
Old Apr 25, 2018 | 10:04 PM
seventyseven250
I was shaking like a leaf by the time we got there. Pretty stressful .
Old Apr 26, 2018 | 05:50 AM
Tom's Avatar
Tom
I've gotta disagree with folks here, 5K in the bed of an SRW truck is well beyond the tire and axle capacities.
Dead empty you've got almost 3,000 lbs on that axle with just the weight of the truck. Add 5,300 lbs and you're north of 8,000 lbs on that axle that was never rated for more than 7K. I've overloaded things more than a few times over the years, but I've learned that exceeding tire and axle capacities can be a recipe for trouble. Sounds to me like you didn't hurt anything, but I wouldn't want to try that a second time. The risk of tire/rim failure is greater than you may think because the truck is riding on the bump stops without any room for the suspension to move when you hit a bump.
Glad you got it home okay, but I wouldn't suggest repeating the performance. Cool photo, though!
Old Apr 26, 2018 | 07:11 AM
DogRidesInBack's Avatar
DogRidesInBack
I once did 2 scoops in a half ton truck, another vote for never again.
Even in a 3/4 ton, that 3rd scoop was way more load.
Owenage
Jan 10, 2018 02:36 PM
pfb
Jul 14, 2007 12:05 PM
ernesteugene
May 28, 2007 04:49 PM
nick65f100
Jun 3, 2006 09:30 AM
