A quick question. My 1950 F1 is fitted with a new 5 dial Dolphin dash insert. It has 2 green lamps for left and right indicators. Could someone confirm please that the original Ford dash also had 2 indicator bulbs on the dash ?. Many Thanks.
If you mean turn indicators in the instrument cluster, the answer is no.
Restored gauge cluster.
Thank you for your reply. So the original dash does not even have one indicator bulb in the instrument panel ?. I also do not see a high beam indicator in your picture ?.
No. The after-market directional stalks you can add to the steering column have little lights that may light up when you signal, but since these weren't an option on these trucks, there's no way to integrate them into the stock dash.
It sucks, because I keep forgetting to turn mine off, lol
Yes, it's there near the top between the fuel and oil pressure gauges. Looks like a black dot there because it isn't on.
