Dash lights
Old Sep 29, 2015 | 09:17 PM
countryboyco99's Avatar
countryboyco99
Dash lights
OK new question. I have a 1980 Ford F100 custom and the lights on the instrument cluster bezel do not match up to what they are supposed to be. For example the right turn signal flashes the brake warning spot. The wires for the gauge cluster don't look like they have been messed with. A little confused on this, does it mean it's not the correct bezel or is something else wrong? Everything else seems to work fine, All the gauges and and dash lighting. Any help would be appreciated! Thanks in advance.
Old Sep 30, 2015 | 07:42 AM
Franklin2's Avatar
Franklin2
I believe there were some differences from the 1980 and the later years. Someone has been in there swapping stuff. See if you can get in there and move stuff around to it's proper location in the top of the dash. What you are complaining about is not in the lower part of the cluster but the upper part correct? I can't remember exactly, but can't they be moved around?
Old Sep 30, 2015 | 08:50 AM
ctubutis's Avatar
ctubutis
Take a stroll through the subforums and the sticky, it's described in there... the 1980 wiring is different, and it sounds like somebody installed a 1981+ cluster - probably because it has a tachometer or some such and the original didn't.
Old Sep 30, 2015 | 08:56 AM
countryboyco99
Thank you I will have to look again. It does not have the tach (I wish it did though) I think the cluster is the right one for the truck I just think the dash bezel was changed.
Old Sep 30, 2015 | 10:22 AM
countryboyco99
https://www.ford-trucks.com/forums/s...1028455&page=2
OK found it. Sorry I should have looked a little more before posting. Thanks for all the help
The link I copied looks like it will fix the problem
Suffolkman
Apr 23, 2018 05:04 PM
68turquoise300I6
Oct 28, 2014 10:34 PM
Jacks '66
Mar 13, 2005 09:44 AM
Beast12
Electrical Systems/Wiring
May 16, 2004 04:38 PM
Traderjoe28
Sep 3, 2003 12:52 PM
