Normal operating temperature range for 2017 TorqShift 6 speed?
Hey guys. What's a normal operating temperature range for the 6-speed TorqShift married to a 6.2L in an F350 DRW? I've searched the forum and not found a definitive answer. I'm about to upgrade to slide-in truck camper that weighs ~5,200 pounds fully wet. Well within my payload but I plan to take this through the mountains, up and down some dirt roads at slower speeds, etc. Just want to know what I should expect to see as 'safe' transmission temps? Truck has 5,000 miles on it. TIA!
Thank you. That was specific to the -G transmission; however, this post seems to insinuate that the truck's display of the transmission temp should not exceed 220 degrees for more than 30 mins, and never more than 250. Am I reading that correctly? I did search the forums but found mostly conjecture and little in the way of hard numbers. And, frankly, I'm surprised the truck won't alert when the transmission overheats.
Why do you think it won't alert you if the transmission were to overheat?
Do you know what the acceptable operating temp ranges are for the current generation TorqShift 6-speed married to a 6.2L? And do you know if the truck will alert if the trans gets too hot?
Thanks for taking the time.
I do not know the temperature operating range for the newer transmissions. That was developed after I left.
The older transmissions would flash the OD OFF or Tow/Haul light when the transmission overheated, and would also set a diagnostic test code for the overheat. That happened at 275°F. I don't know what temperature that will happen with the 6R transmissions, but I'm very confident that it will happen at some temperature. It won't happen below 250°F because that is in the normal operating range.
workingdog
08-11-2006 11:36 PM
