Recommended Temperature Range
Old Aug 11, 2006 | 09:16 AM
workingdog's Avatar
workingdog
What is the recommended temp range for an FE. I know most thermostats are start at 180 for the bottom, but what range would be normal for a hard working truck. Or, to put it another way, at what temp should you shut it down.
Peter
Old Aug 11, 2006 | 02:04 PM
Freightrain's Avatar
Freightrain
I can't see a reason for anything over 195-200 degrees on a hard pull. If you do then you need more cooling capacity.
I keep all my stuff under 190 degrees for the most part. It may heat soak after shutting down, but on average running, I keep 190 degrees
Old Aug 11, 2006 | 04:29 PM
workingdog's Avatar
workingdog
That's what I thought. In a conversation with Summit Racing about my setup they said 210 was within "normal".
Old Aug 11, 2006 | 04:44 PM
73F100*8Mile's Avatar
73F100*8Mile
Garbage Manufactured doesn't make their fans kick on till 210! Better for combustion, worse for engine life. Keep 'er around 190.
Old Aug 11, 2006 | 11:36 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Many FE powered trucks (late 60's) came with a 160 stats from the factory, cylinder wear is higher at 160. At 180 you have reduced cylinder wear by quite a lot, at 195 a little less but then detonation problems with todays bad gas. At over 600K miles on rebuilds I see no problem with 180 stats with less detonation problems, your decision.
True modern engines run hotter like 205 degrees but then we're working with 45 year old design motors vs newer must meet smog requirements motors.
.....=o&o>.....
stuart olson
24
Apr 22, 2019 06:34 AM
P4IN COMM4NDO
110
Dec 10, 2016 08:07 AM
Ford4you
Aug 13, 2016 10:02 PM
tperk100
Feb 7, 2011 03:00 PM
92Custom
Oil & Lubrication
Aug 28, 2002 10:37 PM
