Pan temp vs Trans temp
Old Feb 25, 2014 | 10:29 PM
meborder's Avatar
meborder
In general, is the temperature of the transmission pan indicative of the actual operating temperature of the transmission?
Can you shoot the pan with an IR temp gun and get any kind of meaningful information from that reading? I've noticed a few degrees difference across the pan, so I realize it isn't "exact" but is it close enough to tell if it is too hot?
thanks!
Old Feb 26, 2014 | 08:12 AM
projectnitemare's Avatar
projectnitemare
It should be a close indication. Most aftermarket trans temp gauges are plumbed into an aftermarket pan with a bung for the temp probe.
Old Feb 26, 2014 | 12:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Most aftermarket trans temp gauges are plumbed in the the test port on the side of the transmission. That is a good location for an average transmission temperature.
The pan will show you the coolest temperature in the transmission. Everywhere else is hotter. How much depends on how the transmission is being used at that moment.
Old Feb 27, 2014 | 01:03 PM
meborder's Avatar
meborder
so it is safe to assume that if the pan is too hot, the trans is too.
but not safe to assume that because the pan is not too hot, that the trans is not overheating - depending on how it was used.
is there a better place to try and get a reading with an IR gun?
now ... how hot is too hot?
is that fluid dependant, or is it transmission specific?
Old Feb 27, 2014 | 01:10 PM
khadma's Avatar
khadma
Carpenter Local 745
Good question.
I have yet to install my temp gauge on my E4OD. The aftermarket pan I have, of course, has a sensor
mounting location.
Is it worth installing it there?
Old Feb 27, 2014 | 09:27 PM
Mark Kovalsky
There isn't a good place to read the trans temp with an IR gun.
Up to 220°F for no more than a half hour at a time, and not over 250°F at all.
It's transmission specific.
mounting location.
See this:
So if what you want to know is the coolest temperature in the trans, use the pan. I don't know why you would want that, but to each their own.
Old Feb 28, 2014 | 06:34 AM
meborder's Avatar
meborder
does that 220°/250° range apply to current fluids that meet Mercon/Dex3 specs?
(i realize that anything meeting the Mercon spec is not being tested)
Old Feb 28, 2014 | 08:20 AM
Mark Kovalsky
Who knows? Those temps were good for MERCON fluids when Ford was licensing MERCON. Now anyone can produce anything and say it is for use in transmissions that require MERCON. I don't know what you are getting with those fluids, and I'll bet you don't know, either.
Old Feb 28, 2014 | 01:02 PM
meborder's Avatar
meborder
fair enough.
thank you.
Old Feb 28, 2014 | 02:36 PM
khadma's Avatar
khadma
Carpenter Local 745
Thank you also, I will install the temp gauge at the test port.
bobv60
Jun 4, 2015 09:51 PM
chris86924
17
Aug 4, 2012 08:03 PM
wreckinball
17
Mar 8, 2011 02:16 PM
a2b
Mar 26, 2007 04:29 PM
unger316
Sep 17, 2006 11:33 PM
