e40d(??) slipping (??)
Old Mar 28, 2018 | 02:01 PM
rla2005's Avatar
rla2005
The issue is mechanical. No codes flagged in the KOEO, CM or KOER. Mark can give you better advice from here.
Old Mar 29, 2018 | 10:56 AM
nezihv's Avatar
nezihv
since it does the same noise when revved up on Park, I believe it is not related to the transmission. Just 2 options left, torque converter and the engine.
I am trying to figure out if TC stays engaged at all times or just when I put it on Drive. Once/if I can figure that out, it will lower the possibilities just to the engine which I am 'little' better working on. I can at least change the spark plugs/wires/coils if needed.
Old Mar 29, 2018 | 11:36 AM
rla2005's Avatar
rla2005
The torque converter is attached to the flexplate which is attached to the crankshaft. This means the torque converter is spinning whenever the engine is cranking or running.
Old Mar 29, 2018 | 01:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
As mentioned above the torque converter is ALWAYS engaged. There is also a clutch inside the torque converter, but that doesn't engage until approximately 40 MPH.
Goose52
13
Nov 19, 2020 07:19 AM
Rather be Strokin
Apr 15, 2015 10:03 PM
XionTheBrony
33
Feb 28, 2013 10:59 AM
Jesse1989
1978 - 1996 Big Bronco
May 4, 2011 06:13 AM
smolicht
Nov 16, 2006 09:53 AM
