insulator bed pads
Old Mar 14, 2018 | 09:05 AM
Robert S's Avatar
Robert S
insulator bed pads
I am getting ready to paint my truck, after a quote of 6k++ to paint it. I have new bed bolts just in case I am unable to remove the old and have to cut them out. I have noticed there is a listed insulator pad that I am assuming is between the bed and the frame. Do these generally need replacing? Is it similar to body mounts? What is recommended pads to use? I know there are some poly for the body but unable to find these for the bed. Thanks
Old Mar 14, 2018 | 09:14 AM
95fiveoh's Avatar
95fiveoh
They are really thin plastic pads, I wouldn't worry about them. They shouldn't need replaced. Worst case scenario you could make them easily out of some sheet plastic. I certainly wouldn't pay Ford for replacements.
Old Mar 14, 2018 | 09:19 AM
Robert S's Avatar
Robert S
Cool! That is what I was looking for, I wasn't sure but thought it may be just that. TY
Old Mar 14, 2018 | 04:39 PM
Diesel_Brad's Avatar
Diesel_Brad
They are rubber. Thin like a inner tube. The typically are in perfect shape
Old Mar 14, 2018 | 07:03 PM
Robert S's Avatar
Robert S
Thanks Diesel Brad, I just about have the bed off, I could not believe that all the bed bolts unscrewed. Besides surface rust it is spotless under there, so grateful!!! I had more problems with three bolts that were from a 5th wheel receiver LOL. Hope I can get my buddy over to help pull it off tomorrow. It has a Roll-a-long rear bumper and welded plates to the frame with the tow hitch, I so wish it didn't so I could easily put a regular step bumper on it.
Old Mar 14, 2018 | 08:26 PM
Eddiec1564's Avatar
Eddiec1564
That is what I used to replace the missing insulators on my truck. A old bike inner tube.
They are there to keep the squeaks down when the bed and frame flexes. I finally had enough of that "cricket" and used a old inner tube. Over 8 years now with no more "cricket".
Old Mar 14, 2018 | 08:29 PM
95fiveoh's Avatar
95fiveoh
Sounds like good news. I didn't even bother trying to unbolt my bed bolts. I just hit 'em with an angle grinder. I bought new bed bolts from Ford. Good Lord are they expensive. The bed floor on my truck was so thin you could stab through it with a screw driver pretty much everywhere. Needless to say I replaced the bed.
Old Mar 19, 2018 | 08:53 PM
Robert S's Avatar
Robert S
So I have the bed off, it appears that these insulators are only on the middle area of the frame and only 4, is this correct or should there be insulators at the bed holes as well?
Old Mar 20, 2018 | 05:24 AM
Diesel_Brad
4 is correct
Iaff113
Jun 8, 2016 11:24 AM
learpilot
Mar 19, 2009 07:50 PM
86F150302
Feb 3, 2008 03:29 AM
Lwlandy
Feb 7, 2007 10:29 AM
Nightrain
1983 - 2012 Ranger & B-Series
Feb 27, 2004 02:19 PM
