Cornering light
Old Mar 19, 2018 | 10:55 PM
Robert Long's Avatar
Robert Long
Cornering light
I would like to install a set of cornering lights on the 95 F150. Not being familiar electronics I was wondering if anyone had done this before?
Old Mar 20, 2018 | 03:06 AM
mrollings53's Avatar
mrollings53
Doubtful that anyone has bothered to add them to anything. You could just wire them in with the turn signals, but they would flash. You could jumper the original location in the fuse box, add a second flasher can, and wire up each side with it's own can. This way you can use the turn signal switch to power the lights via relays without them flashing. There would be a relay for left and right side; the outputs of both relays would be wired together. This eliminates back flow too. Normally it would be wired like this: 12V source>flasher can>turn signal switch>turn signal lamps. Instead you would wire it like so:12V source>turn signal switch>(left turn signal>cornering relay & left turn signal flasher can, right turn signal>cornering relay & right turn signal flasher can)>turn signal lamps.
Old Mar 20, 2018 | 07:59 AM
Robert Long
Thanks I"ll give that a try.
stecz
Jan 11, 2024 05:35 PM
HVACTOM
Feb 14, 2015 04:33 PM
stownsen914
Apr 23, 2014 08:44 AM
89BroncoHolic
1978 - 1996 Big Bronco
Jun 5, 2009 12:21 AM
2explorers
Jun 26, 2003 05:40 PM
