2005 turbo
Old Mar 30, 2018 | 03:12 AM
bismic's Avatar
bismic
Originally Posted by bismic
EBP sensor clean, tube clean? What are the EBP, MAP, and Baro readings at KOEO?
VGT connector on tight?
Any codes?
What are the readings above at "Key On Engine OFF"?
As Bryan is saying - Verify the units on each reading (preferably they should be configured to be the same units (psi is best IMO).
Old Mar 30, 2018 | 06:18 AM
SmackDaddy's Avatar
SmackDaddy
I have a good ‘03 turbo for sale, just upgraded to a Powermax.
Old Mar 30, 2018 | 12:49 PM
mrwrench's Avatar
mrwrench
BARO is 29 inchHg
Old Mar 31, 2018 | 06:23 PM
mrwrench's Avatar
mrwrench
all connectors are OK , no check eng light , but I found a stored code for the ebp sensor...
I plan to take the turbo off next week , I would like to put a 10 blades wheel....
Old Mar 31, 2018 | 08:40 PM
navistarnut's Avatar
navistarnut
Code number please.
Might be time to take the EBP sensor off and clean or possibly replace, also clean the tube
Old Mar 31, 2018 | 09:58 PM
Yahiko's Avatar
Yahiko
While your at that also give the harness a very close look for any damaged insulation.
At that connector is the prime place for a short that does all sorts of strange things.
Old Apr 11, 2018 | 01:39 PM
mrwrench's Avatar
mrwrench
I just changed the EBP sensor , and the turbo works great!!!!
Thanks so much all!!!!
Ray Hamel13
Sep 24, 2015 10:20 PM
Iaff113
Feb 23, 2014 06:47 PM
sand1
May 11, 2013 08:00 AM
amill
Mar 16, 2013 09:07 AM
egregg57
Feb 7, 2012 12:47 PM
