2005 turbo
Old Mar 1, 2018 | 09:56 AM
mrwrench's Avatar
mrwrench
2005 turbo
Why my turbo doesn't make any sound? it sound like it doesn't have turbo.
Also the engine is to loud like 5.9 Cummins.
Very slow on take off , most of the time the boost get fixed in 5 psi, while the rpm get higher .
The turbo is not sticky - no codes -in gral it runs great but louder and lazy on take off.
It was in the dealer but it passes all the tests......
Old Mar 1, 2018 | 10:37 AM
navistarnut's Avatar
navistarnut
Take it back to the dealer and tell them to fix it like a dealer should.
Making only 5 psi passing a test does not make. They should know better. Pretty low standard for passing a test IMO.
If you want to for starters, check the MAP hose and nipple for gumming up/residue.
Are all the CAC boots free of tears and tight?
Old Mar 1, 2018 | 02:21 PM
mrwrench's Avatar
mrwrench
Map hose is new and the nipple is clean.
Cac boots clean and tights ...
Old Mar 1, 2018 | 02:47 PM
bismic's Avatar
bismic
EBP sensor clean, tube clean? What are the EBP, MAP, and Baro readings at KOEO?
VGT connector on tight?
Any codes?
Old Mar 1, 2018 | 02:59 PM
69cj's Avatar
69cj
Boost maxing at 5 psi is not normal. Take it back.
Old Mar 2, 2018 | 05:50 PM
mrwrench's Avatar
mrwrench
clean map nipple , clean ebp tube . no codes .
Old Mar 3, 2018 | 01:00 AM
Yahiko's Avatar
Yahiko
Is the VGT wire even plugged in on the turbo?
If you want to check the system for leaks. Take the air cleaner and intake tubing off up to the turbo inlet and use a rubber fernco coupling with a cap that has a connector
for regulated air pressure. Set the regulator for no more than 25PSI and if at the same time you want to check the exhaust then also cap the end of the exhaust pipe also. Put air to it
and start feeling around all piped for any air leaking out. Also remove the cap on the degas tank just to be sure that you don't have any air going that way.
Old Mar 17, 2018 | 08:39 AM
mrwrench's Avatar
mrwrench
All looks ok ,my concern is why my truck sound like she doesn't have a turbo.
I don't heard any vacuum or blowing sound like all 6.0.
this is my 3rd 6.0 and I did not have this issue on my previous trucks.
She is getting 90 k miles and the engine is so clean -I check the MAP nipple and no carbon also I remove the EBP sensor and no carbon in the tube...
The turbo was replaced for a reman turbo before I bought the truck ....
question: can I put a 03 turbo with pedestal in a 05 ?
thanks all....
Old Mar 17, 2018 | 10:06 AM
69cj's Avatar
69cj
If it maxes at 5 psi it isn't passing all the tests. It just flunked that one.
Old Mar 17, 2018 | 10:56 AM
navistarnut
thanks all....
You can use the 05 pedestal, just leave the back bolt out like others have. In fact I'll bet 50% are missing one bolt or another at some point.
It ain't going anywhere.
Have you actually removed the turbo from the truck to confirm it's not sticking? 90k whopping miles........low mileage garage queen is a good candidate for sticking vanes.
Like Mike says above, it most certainly does NOT pass the dealer test, unless they have the bar set so low that they either don't know, or don't give a crap
Old Mar 20, 2018 | 12:35 PM
mrwrench's Avatar
mrwrench
I cleaned the turbo 10/15 k miles ago and it wasn't too bad , I saw it is a reman turbo.
Old Mar 20, 2018 | 12:38 PM
mrwrench's Avatar
mrwrench
nothing changes after the cleaning , same issue ....
Old Mar 20, 2018 | 12:46 PM
navistarnut
Did you ohm out the VGT solenoid?
Perhaps it's not working properly
How long ago was 10 to 15k miles?
Also curious, how did the unison ring look? Was the actuator pin cut out egg shaped?
Old Mar 29, 2018 | 08:43 PM
mrwrench's Avatar
mrwrench
some values in idle :
VGTDC 41.63 not passing 52 under acceleration
EBP 19.1
MAP 14.1
BARO 29
with the on the VGTDC is 00.00
Old Mar 29, 2018 | 10:12 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
BARO is screwed. If it's in psi is should be ~14.
Edit: Shoot, if 29 is inHg it's fine. Jumped out at me and I didn't think before firing off because it was different than MAP. Book is in kPa (psi), but 29 is almost dead on for 1000' AMSL.
