Error Code after changing Fuel Filters
Old Apr 11, 2018 | 02:30 PM
bvieages's Avatar
bvieages
Changed both fuel filters in my 07 6.0. Went to town filled it and the next morning started it up and the engine light came on and got a DTC of P0460 "Fuel tank level indicator circuit malfunction", I checked for leaks, checked the fuzes and looked underneath to see if any of the wiring had gotten damaged. Anyone else run across this? Thanks in advance.
Bryan
Old Apr 11, 2018 | 02:39 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
How long had you gone since filling up last? I've popped the code before, since I'm harpooned I can stuff in 5 extra gallons over "full", and I filled up several times between 5-8 gallons to keep the tank full since it was swinging above and below freezing so often; the sending unit didn't drop below full for probably 400 miles and it popped the code. Cleared it, never came back since the needle started dropping on the next tank I ran.
Pretty common problem on people with aux tanks apparently; if you gravity feed the aux tank from full main tank the sending unit doesn't drop for enough miles and throws the code.
IMO, reset and drive on. If the needle still doesn't drop after 200 miles, pull the sending unit and check it.
jspringator
Jul 13, 2017 10:18 PM
tlolesen
2004 - 2008 F150
Nov 7, 2014 08:31 PM
mx930
Feb 13, 2013 09:11 PM
gunnarGSD
Jun 21, 2011 09:39 PM
Kep4
Apr 10, 2007 07:08 AM
