Lets Talk Shocks
Old Feb 12, 2018 | 07:27 PM
  #31
Larrymac52's Avatar
Larrymac52
Originally Posted by Tricon
You definitely don't need a 2.5, you might be perfectly happy with a Rancho 9000. They are cheap enough that you can't go that wrong with them.
If I were in your shoes, I'd go with a Fox 2.0 with a reservoir up front and a reservoir with an adjuster in the rear. Order them from Accutune and tell the you want a softer ride and what you're using it for. They'll model out the valving, build them and ship them out and you won't have to tinker at all. Just crank the adjusters up when you're towing and back down when you're unloaded. Best of both worlds and not that expensive comparatively speaking.
my problem might be expressing to Accutune how soft a ride I would want until I have actually driven the truck. Probably my best bet would be the Rancho 9000xl’s which would allow me to adjust until I found the right fit for me. Already there are enough testimonials on this site of people stating what they accomplished with their Settings when unloaded and their adjustments to when they were hauling a heavy load.
Old Feb 12, 2018 | 07:45 PM
  #32
Cabindweller's Avatar
Cabindweller
Originally Posted by 86paGT
what settings are you using with no load? I started at 5/3 but haven’t driven enough to see where the sweet spot is.
I’m running 5/3 right now but usually run 3or4/2. I will be going back to that as I prefer the ride softer when not towing my fifth wheel.
Old Feb 13, 2018 | 02:23 PM
  #33
Larrymac52's Avatar
Larrymac52
I ordered the Rancho 9000 XL’s. Seems like the simplest fix for my simple needs. They were on sale and there is also a $50 cash back on the purchase (Visa card) so the net was $340 for the 4.
Old Feb 13, 2018 | 03:41 PM
  #34
Buliwyf's Avatar
Buliwyf
Proper valved shocks get very firm in the winter.
The little 1" pistons in little OEM shocks don't show it as much, because they're such pathetic little shocks with not nearly enough damping. But when you get into real shocks with larger pistons, oil thickness is much more easier felt. To the point where Carli offers different valving for canuks and Alaskan's.
blackford97
Aug 14, 2012 07:41 PM
A H DEVELOPMENT
Nov 15, 2011 01:12 PM
jgrm2
1997 - 2003 F150
Jul 21, 2004 07:39 AM
94' Ford
Jul 12, 2004 05:49 PM
MKJRH 00
Aug 19, 2002 11:18 AM
