Twin I beam years?
Old Feb 10, 2018 | 09:25 PM
Obs7.3Powerstroker's Avatar
Obs7.3Powerstroker
Twin I beam years?
I am trying to figure out what years truck came with twin I beam and which ones came with straight axles? I have a 1996 f250 with a straight axle, my buddy has a 1995 f250 with twin I beam. Did they switch axles in ‘96?
Old Feb 10, 2018 | 09:53 PM
Nothing Special's Avatar
Nothing Special
You might be confusing terms. Twin I Beam is a 2WD suspension, and it's been many decades since Ford put a solid axle in a 2WD.
So, assuming you are talking about 4WD, all F-150 and F-250 '80 - '96/'97 were Twin Traction Beam. F-350s were TTB from '80 to (I think) '85, and solid axle from (I think) '86 - '97.
The solid axle in your '96 F-250 is not stock (but it is an easy swap).
Old Feb 10, 2018 | 09:58 PM
Obs7.3Powerstroker
Twin traction beams is what I meant. A buddy told me my front axle was a Dana 60. Don’t know if he knew what he was talking about. Any way to tell?
mrollings53's Avatar
mrollings53
4x4 F350's received the Dana 60 front axle, F250's got the TTB Dana 50. Neither received the twin I beam, that was used on 2wd trucks(if it was even still called that). Someone installed the axle on your truck.
Old Feb 10, 2018 | 10:01 PM
mrollings53
Count the bolts on the front cover/compare cover shape.
Obs7.3Powerstroker
That’s what I figured. Just wanted to double check. I’m pretty sure the previous owner wanted to make it a 350 because it has the 350 front axle and the 350 leaf spring helper. They even put on f350 badges.
Old Feb 11, 2018 | 10:32 AM
Nothing Special
Actually a lot of 4WD F-250s had the Dana 44HD TTB. (And older F-350s had TTB too, but not in the '87 - '97 years this forum is about)
Yes, the 2WD suspension was still the Twin I Beam though these years. In fact, my 2015 E-450 motorhome has twin I beam suspension.
Old Feb 11, 2018 | 10:35 AM
95fiveoh's Avatar
95fiveoh
What is the difference between a standard Dana 44 TTB and a Dana 44HD TTB?
Old Feb 11, 2018 | 01:12 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Swapping an axle and badges will not make a truck into an F350. This is tied into the VIN code and you could get yourself into quite a bit of trouble should you decide to load this truck to F350 specs.
Still, there is no harm in faking it, just remember you have an F250.
Old Feb 11, 2018 | 01:13 PM
Nothing Special
I'm not sure. Dana 44 was used in F-150s and Broncos, Dana 44HD in F-250 and F-250HD (except for the F-250HD that got Dana 50s).
I know that the 44 had a 5 bolt pattern for the wheels while the 44HD had 8 (which really isn't that significant since that's just how the hubs are drilled). The 44HD might have bigger brakes? I don't think there was any difference in the diff, axle shafts, spindles or wheel bearings (but I could be wrong there). I sort of suspect that it was a distinction without much difference because F-250 buyers wouldn't want to hear that they were getting a 1/2 ton front axle (which really would be nothing new, because until the 4WD F-350s came out in ~'78 there wasn't anything stronger than a Dana 44 front axle in pickups).
By the way, I've heard that F-250s would get the Dana 50 if they were SuperCabs, crew cabs, or if they had a snowplow package, and a Dana 44HD otherwise. But in Ford form, there probably was more flexibility than that, and you simply have to look to see what your truck has.
Old Feb 11, 2018 | 03:15 PM
My4Fordtrucks's Avatar
My4Fordtrucks
.....and it's been many decades since Ford put a solid axle in a 2WD.
Didn’t the F-Superduty have a solid axle? They were only 2 wheel drive.
Old Feb 11, 2018 | 05:56 PM
Diesel_Brad's Avatar
Diesel_Brad
Solid I beam axle(think tractor trailer front axle)
And the 99+ F450 and F550 2wds are solid axle(looks just like a 4wd axle but just a straight pipe from knock to knuckle with no pumpkin)
Old Feb 11, 2018 | 05:59 PM
Diesel_Brad
That really means nothing since the D44, dana 50 and dana 60 all use 10 bolts on the front cover
Old Feb 11, 2018 | 06:57 PM
mrollings53
Do they all have the same thing stamped where "Model Number" is on the diagram?
jays92
Oct 1, 2013 10:19 PM
bigford250
Dec 20, 2007 09:42 PM
chiaml
13
Jun 18, 2007 10:45 PM
87carbed
Aug 2, 2006 12:15 PM
Godzilla250v10
Nov 5, 2002 08:43 AM
