No dash lights!
Old Sep 15, 2003 | 03:07 PM
Truckmano5's Avatar
Truckmano5
No dash lights!
Ive tried new bulbs to get my dash lights to come on but it hasnt worked. i need some advice on this one since im auto-electronically challenged.
Old Sep 15, 2003 | 03:54 PM
Mil1ion's Avatar
Mil1ion
No dash lights!
Is this on the 78 like in your sig?
You didn't say what truck it was.
Old Sep 16, 2003 | 07:54 AM
Truckmano5's Avatar
Truckmano5
No dash lights!
Yes, the 78 has no dash lights.
Old Sep 16, 2003 | 11:32 AM
Mil1ion's Avatar
Mil1ion
No dash lights!
Do you have an ashtry light ? and does it work ?
Does the dome light work with the switch ?
If they do,you will have to remove the instrument cluster.
If they don't,you can get a new headlight switch.
I trust you know how to remove the cluster?
You will need to check the printed circuit and the pin connector going to the cluster.
Sometimes they get brittle, and cause problems.
You will need to check the bulbs as well.
That's it for now.
Old Sep 16, 2003 | 11:37 AM
Truckmano5's Avatar
Truckmano5
No dash lights!
My main problem is that the previous owner(s?) did wonders on the wiring. The dome light has never worked. Bought and tried new headlight switch; No luck there. I think my printed circuit is bad are there is a serious wiring problem. Thank you for your advice, mil1ion.
buckeyeplayer
Jan 29, 2008 05:35 PM
Oldfordtech
Jan 10, 2003 09:50 PM
WXboy
1983 - 2012 Ranger & B-Series
Dec 28, 2002 09:06 PM
marrug
Nov 27, 2002 11:49 AM
gtex
Nov 16, 2002 08:48 AM
