Help dash lights quit working.
Old Oct 21, 2002 | 10:55 PM
gtex's Avatar
gtex
Old Nov 9, 2002 | 09:40 PM
unioncreek's Avatar
unioncreek
I have a 69 F350 that I have owned for about a month.
The dash lights worked when I got it. My son used it last
night and they quit working. I put a new fuse in tonight,
but they didn't work. I checked the connection to the
dash and it was good and tight. I decided to check the
fuse panel again and there is not power at either end of
fuse. Has anyone run into this before or know where I
should look for the problems.
Thanks,
Old Nov 9, 2002 | 11:08 PM
DieHardFE's Avatar
DieHardFE
The problem you are having is most likely your light switch. I know what your thinking, "the headlights still work" right? There is a resistor the is built into your switch that allows you to dim your dash lights, chances are your switch is 20-plus years old. I would think it's safe to say it's time to replace it. That would explain why you don't have power to either side of your fuse. Hope this helps.
Ever notice the first letters of FEarsome?
With to many to list...
DiehardFE
Old Nov 10, 2002 | 06:45 AM
jowilker's Avatar
jowilker
Bob, Rotate the **** left-right and see if that makes any difference.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Nov 10, 2002 | 04:17 PM
geoaigel's Avatar
geoaigel
>difference.
Good advice John. ;-) Seriously, my dash lights work only at exactly one spot on the entire range of settings of the switch. HTH, George
Old Nov 10, 2002 | 05:03 PM
unioncreek's Avatar
unioncreek
I found the problem, it was the switch. The dash lights
will light up when you get the switch in just the right
position. I will have to pick one up when I get to town.
Have you ever noticed that it is something simple and we
always make it more difficult.
Thanks,
Old Nov 11, 2002 | 12:53 AM
geoaigel's Avatar
geoaigel
It wasn't made more difficult, was it? How would you know that there is a dim switch on a pickup truck? I was surprised myself about that, that is quite fancy! Who needs to dim their interior lights on a pickup? They must have had only that switch to bolt on. Glad we could help and the fix was so easy!
Cheers, George <--- keeping his one position dim
Old Nov 11, 2002 | 05:28 AM
jowilker's Avatar
jowilker
George They have had that feature as far back as I can remember, and still do.
John
jowilker email me
Old Nov 14, 2002 | 06:52 PM
rebocardo's Avatar
rebocardo
If you clean the little pad, put some dielectric grease on the coil, and bend the pad arm so it makes better contact you might avoid that $10 replacement next time.
Old Nov 16, 2002 | 08:48 AM
unioncreek's Avatar
unioncreek
I swapped out a new switch from my 72 F100 since it won't
used until my son is old enough to drive. I don't know
where you get the switch for $10.00, but locally they are
$28.00 and online the cheapest is $18.00
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
