Biggest Complaint
Old Jan 25, 2018 | 02:06 PM
  #91
IHC120's Avatar
IHC120
The ridiculously low hanging rear axle shock mounts.
Old Jan 25, 2018 | 06:33 PM
  #92
Harry500's Avatar
Harry500
Another Supercab complaint: No external rear door handle, no operational windows in rear doors either. My old lowest grade Chevy truck at work has both, and its several years old. This is actually indefensible, and embarrassing...
Old Jan 26, 2018 | 05:17 AM
  #93
Stocks557's Avatar
Stocks557
The rear windows do go down in Supercab? Ford chose to keep the suicide doors based on customer preference.
Old Jan 26, 2018 | 07:07 AM
  #94
troverman's Avatar
troverman
Originally Posted by blamkin86
...No, by far my worst complaint is the way the throttle and transmission work.
Specifically, when you get to highway speeds (55+) the truck takes a lot of throttle, well over 1/3 of the pedal, before anything starts happening. It never really builds boost, so then you give it a little more gas, and the truck downgears and takes off like a rocket.
I'd love to know if they've updated the software - my truck was built way back in December of '16.
It's just maddening. I'll likely take a long look at the chevy when it comes out this fall. Sorry I know people won't like that, but it is what it is.
All modern vehicles use electronic throttles...no cable drive. The manufacturer sets the programming. "Sporty" vehicles have lots of early throttle tip in which makes them feel really quick off the line, but then they don't have as much to give later in the throttle travel. Vehicles like "trucks" tend to have late throttle tip in. They aren't meant to be "fast" and they hold gears longer in an effort to save fuel.
Now, the F-150 and Raptor have a "Sport" mode which can be turned on...this front-loads the throttle and makes downshifts quicker...giving that sporty feeling some people love but at the expense of fuel economy.
The Pedal commander is in-line. It takes the factory throttle signal from the pedal and amplifies it before sending it down the factory harness. It makes the engine think the throttle is being pressed harder than it is. In reality, you can do the same thing pedal commander does just by being hard on the throttle.
Using what you have, one can always manually shift, or you can try Tow/Haul mode when you aren't towing. That mode allows quicker downshifts.
I've not driven the new L5P Duramax. The Cummins, however, seems to have the worst throttle response unless you buy the manual.
Fordfan17
Apr 26, 2019 11:37 AM
17PSD
Mar 10, 2017 07:54 AM
Ron94150
Mar 18, 2016 08:57 AM
ALMACK
6.2L V8
Feb 29, 2016 03:08 AM
