02 E450 7.3 stalling now no start
Old Jan 16, 2018 | 12:33 PM
HMG_Auto's Avatar
HMG_Auto
Truck began stalling once in a while but only after getting hot. Eventually code came up for cam sensor. Replaced sensor Thursday night with updated sensor. Same issue. Cam code returned after driving around the block.
After doing some research it appeared the IPR could be the culprit (stalling once at operating temp) so that was replaced last night.
Truck started first time rough then stalled. I was able to run a key on engine running test but no codes. It will now not restart.
I have pulled airbox back off to see if I bababooyed something or unplugged something but I cannot see anything that I could have done in there.
Any suggestions?
Old Jan 16, 2018 | 12:38 PM
Walleye Hunter's Avatar
Walleye Hunter
Are you using OEM sensors and IPR? These trucks don't like aftermarket parts there. Did you knock something off or forget to reconnect IPR? Is IPR on with the sleeve and magnet in the right spots? Tinnerman nut on and tight?(I know, but one has to ask).
Old Jan 16, 2018 | 12:40 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Is the new IPR OEM or parts store brand?
How long was the engine running before it stalled after putting the "good" IPR in?
What is the fuel level of the tank?
EDIT: Walleye beat me to it, but you see where we are going with this?
Old Jan 16, 2018 | 12:43 PM
HMG_Auto's Avatar
HMG_Auto
When removed the IPR had the plug/solenoid part on top at 12 o'clock. That is how I reinstalled. Is that supposed to be lined up with the IPR itself?
I had to work almost blind so maybe I misaligned.
I know this I probably a bobo mistake on my part
I'll try to get a picture of how it is installed now.
Old Jan 16, 2018 | 12:46 PM
HMG_Auto's Avatar
HMG_Auto
Truck never made it out of garage after install. It would idle terribly but stall immediately
Part is motorcraft.
Fuel level just below full
Old Jan 16, 2018 | 12:52 PM
Walleye Hunter
IIRC the IPR screws in and then the magnet goes on, connector at 12:00, then the spacer goes on with the fat end on the magnet and the Tinnerman nut holds the whole thing together.
Old Jan 16, 2018 | 07:35 PM
HMG_Auto's Avatar
HMG_Auto
Here's as far as I've gotten
goonski
1997 - 2003 F150
Nov 24, 2008 04:23 PM
montauk198
1997 - 2003 F150
Nov 20, 2008 12:50 AM
NaviGurL4Life
Mar 19, 2008 05:33 PM
Catfish369
Bronco II
Oct 29, 2004 07:04 PM
Catfish369
Bronco II
Oct 18, 2004 07:50 PM
