Sponsored by: Auxito
Shaking like an Earthquake
Old Nov 17, 2008 | 08:36 AM
montauk198's Avatar
montauk198
Unhappy Shaking like an Earthquake
Today: Nov. 17, 2008
1999 Ford F-150 XL
4.2L V6 129,000 mi.
Service engine light came on two weeks ago
code says O2 Sensors. Haven't replaced them yet due to not being able to spend the money yet.
Then last week at 35mph/> truck would vibrate/shake when letting off accelerator. Took it in had the tires balanced and rotated when I noticed the vibration. yet it continued to vibrate.
Yesterday Started to leave work and it vibrates/shakes like i'm in an earthquake.
Side note: April 2007 I took my truck in for an alignment and the shop said they wouldn't do it because the front-end needed to be updated. They told me that some of the parts were bad... So needless to say I had them "update" the frontend and got it aligned...
Old Nov 17, 2008 | 01:00 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE montauk198!
Exactly what DTC did you get when you had the codes read?
Sounds like you have a vacuum leak. An excessive vacuum leak would cause the engine to run poorly and shake. Good luck!
Old Nov 18, 2008 | 08:17 AM
montauk198's Avatar
montauk198
shaking like an earthquake
I don't remember the code I went to Advanced Auto Parts and they used a little orange OBD2 reader and told me it said O2 Sensor...
Old Nov 18, 2008 | 11:14 AM
KingRanchMan02
There are a lot of DTCs that have O2 sensor in the code description. Some concern problems other than a bad O2 sensor. This is why it is important to get the code along with the description. The code is the thing that we would need to be able to help you. I wouldn't go replacing O2 sensors just yet. Take a look at the vacuum line from the PCV and follow it to it connecting point on the intake manifold. This hose may be rotted out causing a major vacuum leak. Good luck!
Old Nov 18, 2008 | 11:18 AM
montauk198's Avatar
montauk198
I firgured out why my truck was shaking.. My Drive shaft bolts were missing.. I had one left hanging on for dear life.. got it to the shop and they saw that i had one of four bolts and the last bolt only had three threads before it came out...
But im going to goto a friend of mine who has a full scanner that gives details in the obd2
Old Nov 18, 2008 | 11:37 AM
KingRanchMan02
Yep, that would do it. Glad you got it fixed. Let us know what that DTC is.
Old Nov 18, 2008 | 06:35 PM
amerimutt's Avatar
amerimutt
Dude, The bolts came loose (and maybe) it's just result of the erratic shaken. Your lucky the shaft didn't fall out and your here to tell about it. Anyway, Same happened here...... Kingranch is dead on. Masive vac leak found under intake throat- Mine, anyway was the from the popular 3/4" elbo fitting fr0m PVC to intake. That's my Holiday inn advice... Thank you..... Oh, your welcome. No thank you.... No absoultly thank!
Old Nov 20, 2008 | 12:29 AM
Bluegrass 7's Avatar
Bluegrass 7
Do not just run with what you were told without understanding what the code is and the discription.
It's not done that way and is luck if it is the problem..
Code only tells you what system is in trouble and not the specific cause.
Doing so will just result in spending money for parts you don't need.
There are many items involved with even a single code.
A store jocky cannot tell you what part is the problem.
Old Nov 20, 2008 | 12:50 AM
khadma's Avatar
khadma
Carpenter Local 745
Take a look at this website.
I have used this tool to help eliminate problems listed by the DTCs.
Remember, 02 sensors are pretty tricky at times, so look at all related items to find a solution.
When you do replace any sensor, it is a good idea to reset the computer and drive the truck to let the computer relearn. A better OBD scanner will let you turn off the CEL when repairs are completed.
OBD-II Trouble Codes - OBD-II DTC Trouble Codes Repair Help Site
