1996 F250 Powerstroke with a miss
Just purchased a 1996 Powerstroke truck has 206,00 miles on it. Was driving down the road the other day and noticed it has a miss in it. Can really fill the miss until about 1500 rpms. Also can hear a loud ticking coming from cylinder #3. Thinking I have a bad injector. Shop performed a buzz test and all worked. They tried a contribution test and it would almost kill the truck and never start. Need some idea's guys. I have never owned a diesel until now.
I don’t have a scanner but will check the fuel pressure.
Are bad injectors a common problem? I did fail to mention I put new glow plugs, internal harnesses, valve cover harness and external pigtails on this past weekend. Electronics are my thing and I know everything was hooked up correctly. Pigtails were soldered into place.
Using a mechanics stephascope the tick was loudest over that injector. When they tried to start the test the truck would stumble really hard. As soon as it did that the contribution test would just not run. We tried 4 times with the same result and two different shops tried it for me also with the same results.
Received 3,697 Likes
on
#4 is driver side second from front, (see top pic in post 4) if time allows swap #4 and #6 and see if problem follows,
npccpartsman
06-11-2017 03:07 PM
ham-n-swiss
06-04-2010 02:37 PM
