On vehicle fuel injector testing
Old Jun 4, 2010 | 07:57 AM
ham-n-swiss's Avatar
ham-n-swiss
My 90 f250, 7.5l has spent much of the last year in storage only started every 4 to 6 weeks or so. A couple months ago it really started to stumble when i did take it out for a drive now and then and it has become so bad it is undrivable. I'm afraid to give it much gas because the severe bucking I'm afraid is going to break something. My question is, could the injectors gum up and fail to open and/or close from a year infrequent usage and is there a way to test each injector while still on the vehicle so I can determine if this is the problem. Are the injector audiable enough that i could hook up a test connector and apply a voltage to them and listen or feel for operation. I have a fuel pressure guage so could I hook that to the fuel rail, pressure up the rail, and then one by one energize the injector and look for a drop in pressure indicating that that injector works. Also, the bucking gets worse as the truck warms up.
ANY comments greatly appreciated!
Phil
Old Jun 4, 2010 | 08:55 AM
l67cooled's Avatar
l67cooled
I can't help you with your injectors but if you haven't changed your fuel filter yet I'm almost positive that's your problem. A cheap place to start anyway.
Old Jun 4, 2010 | 02:37 PM
rla2005's Avatar
rla2005
Use the gauge to test the fuel pressure before going too wild on testing the injectors. It would be a wise idea to check for any stored error codes too.
Shorebreak
May 14, 2015 06:52 PM
greenstar
Apr 1, 2014 06:47 PM
octaneforce
Oct 28, 2012 11:10 AM
farmer12
Jun 17, 2011 08:26 PM
beaudreaux
Mar 17, 2004 09:01 AM
