trans issue
Old Dec 16, 2017 | 12:19 PM
WLDHRSE's Avatar
WLDHRSE
trans issue
Rolling down the road Wednesday night, leaving a stop sign, up to about 20 MPH and all of a sudden I'm slowing down while my RPMs go up. Trans stopped pulling! Never felt anything "break" and didn't hear any noises. Pulled off the road and while sitting still I tried D, 1, 2 , and 3. Same thing in all gears, engine revs but tranny doesn't pull. Then I tried reverse thinking I could back it home (5 miles from the house w/ no stops) but in reverse not only did it not move, but the throttle had no effect at all. I could floor it and the RPM didn't even change.
I shut it down and called a friend to drag me home (w/ his chevy :/ prolly the best day of his life!). It was only about 25 degrees out and just in the 10 min I sat there it cooled down enough that when I restarted it and tried to put it in gear it moved, so I told him to follow me and took off... a 1/4 mile later same thing, rolled to a stop and he ended up dragging me home.
Last night went out to warm it up to check fluid level. When I started it, it went into reverse and worked normal and then into drive and worked normal. I did reposition it in the driveway but did not go for a ride. Once it warmed up the same problems started, no forward gears worked and the throttle didn't work at all in reverse.
Anybody have any ideas what would cause this? Initially I was thinking 3 things, torque converter, fluid, or electronics. The fluid was nice and red and right up to the top of the "full warm" on the dipstick. I don't think its the TC cuz it seems to work fine when it's cold started. I don't know crap about the electronics involved with these trannys... I appreciate any help/info.
Old Dec 16, 2017 | 12:58 PM
DarkStarMedia's Avatar
DarkStarMedia
You need to put a trans pressure gauge on the test port on the side of the tranny and see what your pressures are i the various gears.
Might be low pressure, might be blown diode (mechanical not electrical), might be blown clutch.... not sure. hopefully mark will be around soon... he was on the team that designed the thing iirc.
Richard
Old Dec 16, 2017 | 08:23 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I can rule out the electronics. There is no way that electronics can cause this. It's something mechanical.
The suggestion to put a pressure gauge in the test port on the driver's side of the trans is the best way to diagnose this. Get a 0-350PSI gauge with a 1/8NPT thread. Read the pressure at idle in P, N, D, 3, 2, and 1. Also read those pressures when it won't engage.
Old Dec 17, 2017 | 03:03 AM
Yahiko's Avatar
Yahiko
You got the guy here that KNOWS that trans very well.
Mark I like the signature test you have.
Old Dec 17, 2017 | 10:38 AM
WLDHRSE's Avatar
WLDHRSE
I'm going out to get a gage right now. Thanks for the help guys!
Alsride
29
Jul 25, 2016 09:27 PM
GM4WALLS
May 28, 2015 04:33 PM
cj45lc
21
Jun 26, 2014 08:27 PM
897.3idi
Mar 11, 2012 05:33 PM
jsnelson
Apr 15, 2011 09:31 AM
