jsm180: Right, which is a bad idea. The hitch load is spread on the truck bed when it is stopped. When the truck is moving, the kingpin is sitting on a stick with a ball on top. Great idea.
The AUH doesn't attach to the pucks, only the gooseneck ball.
You are 100% correct ---
This in turn makes it a pretty weak design that is incapable of sudden and unexpected load changes especially, IMO with the aluminum tubing design. If the loads remained static, I wouldn't have a problem - but the loads are dynamic in that they constantly changeThe old steel version would be more forgiving
The kingpin-to-ball-coupler didn't fare too well either.
Actually, the coupler appears to be fine. What you are seeing is a plastic cone that helps to guide the hitch onto the ball, if things are not perfectly aligned.
I use a steel version of the AUH that secures itself at all 4 corners via 5th wheel hitch rails mounted to the frame. 10's of thousands of miles and still think it is a great product.
That said, I have seen the aluminum goose ball version being installed in person and I would not feel comfortable with that at all. I will use the steel, rail version of the AUH or go to a B&W traditional hitch.
We tow heavy cross country with our 2000 7.3 using the AUH and really enjoy the smooth and comfortable ride it affords us. It is not for everyone though and that is OK...
We have the AUH aluminum version and have traveled this year from MD to Yellowstone through PA, OH, IL, IN, IA, SD, WY, ID and then back through with stops in WI, MN, MI, NY, and PA. 5th wheel is heavy but rows like a dream with the AUH, Moryde pin box and recently upgraded hydraulic trailer brakes. Towed the same trailer home with a BW when we first got it and though the BW is solid I would not go back from the AUH.
Guess that piece of manufacturing was because of what happened at the beginning of these posts. I didn't know they came out with that....cool !
That kit has been out for years. And actually if you go back to the original posts from nearly 2 years ago you'll see that lockout kit was installed and it did not help, obviously.
If you look closely you will see that the lockout kit is not installed but instead someone made their own pieces of metal with some bolts to act like the kit. So I would not call this hitch failure since the correct kit was not used.
The drawing for the kit is on Andersen's website, it's just 2 bars and 2 bolts, not exactly rocket science.
The important dimension of the height is not included nor is the thickness of the steel. Saying this is a hitch failure would be like saying a failed regular 5th wheel hitch on rails was a hitch failure because some guy tried to hold the hitch to the rail with a piece of threaded rod.
