Window switch or window regulator?
Old Oct 18, 2017 | 12:53 PM
kefrko's Avatar
kefrko
2000 f350 srw cc 4x4 and been dealing with a temperamental drivers side window for a while. It use to be that periodically it wouldn't want to go down which wasn't the end of the world and then out of no where it would be perfectly fine again. Today it went down and I went to put it back up and it wouldn't go up. Bigger problem. I got home and popped the switch cover off and nothing looked obvious so I got online and started researching. Found a few different forums with posts that pretty much described my problem but unfortunately no one finished up with their final fix. From that I found it most likely is the window switch, the regulator, or possibly chafed wires in the door hinge area. I went back outside with my multimeter and started testing for power. During that test I actually found that the switch decided to start working again and the window went up. I'm leaning toward the regulator being the culprit but wondering if anyone else has any thoughts. When the window isn't working I am getting a click from the dash area which a lot of people described. Also when I put the window up or down it sometimes seems a little sluggish and also it will stop short of going all the way down by about 3/4" sometimes and will go the rest of the way if you hit the button again.
Old Oct 18, 2017 | 02:18 PM
ArmyLifer's Avatar
ArmyLifer
I had an intermittent passenger window. It did exactly as you describe. It was the switch.
Old Oct 18, 2017 | 02:48 PM
kefrko's Avatar
kefrko
That's interesting. I would hate to get stuck with the window down but I guess I could wait until the next time it happens and check the voltage at the switch. The switches also aren't all that expensive so I guess I could also just swap it out and see if that takes care of it.
Old Oct 18, 2017 | 07:06 PM
CousinCarl's Avatar
CousinCarl
You could pop out the switch on one of the other doors and plug it in to the driver's harness and see if it is indeed the switch or not
Old Oct 18, 2017 | 07:07 PM
F350-6's Avatar
F350-6
My guess is the switch as well. Mine acted like that. New switch from Rock Auto fixed me up.
Old Oct 18, 2017 | 07:11 PM
CousinCarl's Avatar
CousinCarl
While you're inside the door panel, you could spray silicone on the rubber side tracks. They could be dry, resisting the window causing it to move sluggish and wear out your motor. I had a motor go out a while back. Window got stuck in the down position. Tapping/hammering the motor would jar it enough to generate the power needed to roll the window up while I awaited my new motor to arrive.
Old Oct 19, 2017 | 12:27 AM
pirschwagon's Avatar
pirschwagon
9 out of 10 times it is the Switch. There is a Diode which eventually doesn't play well with others.
Old Oct 20, 2017 | 04:46 PM
kefrko's Avatar
kefrko
Thanks everyone. I guess I will pick up a switch first and throw it in to see how it does. I will follow up with the results for others in the future
Old Oct 21, 2017 | 08:27 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Another vote for the switch. I had another vehicle that had the same problem and a new switch fixed it up.
Old Oct 21, 2017 | 02:45 PM
Bonanza35's Avatar
Bonanza35
Switch here to, replaced year back and know more problems since. I think I've replaced all the switches over the years but usually they just go out.
Old Oct 21, 2017 | 07:25 PM
bigreentruck's Avatar
bigreentruck
My passenger side started getting intermittent recently. Finally really started a no go picture.
Rang the wires and switch for voltage. Decided the motor had gotten tired. $57 later, no worries. My truck has 174K on it now. No history on it since I bought it 36K ago. Guess it was time.
Old Oct 23, 2017 | 10:35 PM
cutlass's Avatar
cutlass
I had the same symptoms but it turned out to be my motor. After some time, it finally gave out completely.
Replaced it and it now works perfectly.
Huntington
Sep 30, 2020 02:09 PM
timbersteel
Sep 23, 2013 07:14 AM
Eric White
Jun 27, 2012 12:47 PM
oracle
Escape & Escape Hybrid
Oct 7, 2008 11:29 PM
Taboo
Jul 24, 2007 12:24 PM
