Block drain plug stuck.
Old Oct 19, 2017 | 05:42 PM
  #31
diesel_dan's Avatar
diesel_dan
Originally Posted by Monster-4
Timely thread although the poor OP has it hi-jacked! I'm getting ready to do a coolant change this weekend and have the Fumoto valve F108 for the driver's side and a F108SX for the passenger side. Didn't think about the o-rings. Wonder if I can find a Parker Stat-o-Seal in time.
Yeah, Jack 'n me take turns on thread hijacking (notice how Jack is in the middle of that term ), but he's so bad that sometimes he hijacks his own threads!!!
I'd do the SX as it comes, maybe some thread lock/sealer for good measure. I think I'd run counter to the crowd and use the fiber washer and some good thread lock/sealer on the drivers side too. After all, the whole point of putting these on is that they never come off. You can attach a hose to the nipples if back washing the block cavities is your gig. I drained fluid months after mine were put on and it came out FAST (nothing big was blocking the hole) and I got some minor casting sand in the coolant that came out. Then again I have a double-washed-block '07
Jack: you never mentioned we were going to have a party! Great, I get one thing right, and I have to stand in line behind your wife at a party, probably in New Jersey, so I can b*tch slap you (picture the scene in Airplane where the whole line of folks is going to "slap some sense" into the one gal...).
No Washer?! oh the horrors...
Old Oct 19, 2017 | 08:35 PM
  #32
TooManyToys.'s Avatar
TooManyToys.
I don’t get to go to many party’s. Somehow I always write down the wrong address. And then I find my wife’s phone battery is exhausted.
If I was going to use these for the coolant drain, and I haven’t for a good number of years due to the small orifice in the ball valve, I would use my Loctite 567 pipe thread sealing compound. I’ve used this for over 30 years now on all kinds of stuff and have mentioned it here before. It’s a high viscosity compound, and although Loctite brands it low adhesion, there have been many times any of my test guys have struggled trying to loosen fittings. It works on everything well, including some high pressure hydraulic threads that were hurt.
I have a large tube and for it’s a 25-30 year supply. If I’ve doing farm hydraulics, or natural gas fittings ‘cause that’s a bite in the tail leak, a small swipe goes on.
Old Oct 19, 2017 | 09:54 PM
  #33
Yahiko's Avatar
Yahiko
Rectorseal #2 is also a very non-harding option. One plus is it does not eat PVC.
eraser5
Sep 17, 2010 09:08 AM
jaybe
Jun 24, 2007 07:54 PM
Mudder
Oil & Lubrication
Jan 12, 2006 06:16 AM
HD
Oil & Lubrication
16
Jun 11, 2003 05:49 AM
AussieDog
Dec 31, 2001 07:47 PM
