stripped HCFM drain plug
Old Jun 24, 2007 | 10:15 AM
jaybe's Avatar
jaybe
OK I've tried to use the search function on here but either got too much or not on problem info. I've got a stripped out 6mm hex hole drain plug on my HCFM. I know I'll have to get a peplacement (IH part, if old post info are still the way to go), but I have to drain it now. Any quick/better solutions like welding a nut to the brass plug? Is that even possible? F-350 still running OK but water in fuel light illuminates when roundong left hand turns. Would like to solve situation. Thanks in advance for replys.
JB
Old Jun 24, 2007 | 10:19 AM
DesertDave's Avatar
DesertDave
Given that you've stripped out the hex part, and you are going to get a replacement IH plug, when the replacement arrives, try JB welding in a hex wrench to remove the stripped original.
Old Jun 24, 2007 | 12:13 PM
Lonewolftx's Avatar
Lonewolftx
Lightbulb try this . . .
Get an "easy out" drill bit to match the hle size and take it out that way. Have to have the new plug ready when you do it.
Old Jun 24, 2007 | 12:32 PM
20046.0PSDX's Avatar
20046.0PSDX
Have fun w/ the "easy-out" drilling due to the location of the plug. Once its out you'll love the new IH part that has the extended plug that can be hand tightened and yet still retain the hex. It also "holds itself" in the HFCM when removed instead of falling into the drain pan.
Old Jun 24, 2007 | 02:14 PM
Beerstalker's Avatar
Beerstalker
I have heard of many people using JB weld to attach the 6mm hex wrench to the plug and then removing it like DesertDave suggested. I would suggest that as well.
Old Jun 24, 2007 | 02:19 PM
jaybe's Avatar
jaybe
Thanks for the comebacks, I think I'll try the JB Weld after I get in the IH part. Appreciate it guys!
JB
Old Jun 24, 2007 | 02:55 PM
blockmanjohn's Avatar
blockmanjohn
Does anyone just pour the pint or so of fuel back into the tank if there is no sign of water?
Old Jun 24, 2007 | 03:05 PM
WishIhada7.3's Avatar
WishIhada7.3
No i would not reccomend it...that is where all the trash settles It not worth it.
Old Jun 24, 2007 | 05:00 PM
mrxlh's Avatar
mrxlh
JB
Take it to the dealer, the hfcm WIF sensor is bad. It is possible it never got upgraded to the new hfcm without the heater. I had an 03 and had 3 changed out, same simptoms, WIF turning corners. The last one they installed was the new one without the heater. Never had a problem again. Just draining it is not going to stop the light from coming on.
Old Jun 24, 2007 | 06:13 PM
jaybe's Avatar
jaybe
One more question that was not answered....can you weld a nut onto the brass drain plug?
JB
Old Jun 24, 2007 | 07:36 PM
WishIhada7.3
you could tac a nut on there make sure you disconnect the power connector to the pump/heater..
Old Jun 24, 2007 | 07:54 PM
Beerstalker
Could you, probably. But is it really that good of an idea to be welding on something that contains a flammable liquid, even if it is just for a second? Just try the JB weld.
ryhed
Mar 8, 2013 01:14 PM
havns3
Dec 17, 2010 06:14 PM
03pwrstrk
New Member Introductions
Nov 30, 2009 10:33 AM
oldwo
Aug 20, 2007 09:26 AM
wc46
May 17, 2006 11:32 PM
