Sponsored by: Real Truck
Upper Radiator Hose
Old Oct 5, 2017 | 04:48 AM
The Bone's Avatar
The Bone
Upper Radiator Hose
Hey guys
I was cleaning under the hood yesterday and I noticed that my upper radiator hose was like sucked or collapsed for another way of saying it. I never seen this before on any vehicle I have owned. It's like instead of getting fluid from the over flow tank it just sucked the hose closed. I havent driven the truck for about 4 days. 15 F250 6.7
Thanks Guys
Old Oct 5, 2017 | 05:02 AM
Chuck's First Ford's Avatar
Chuck's First Ford
check coolant container vent hole.
second, hose is going bad..
not so common these days.. but 20 plus years ago ... very common.
Old Oct 5, 2017 | 06:02 AM
The Bone's Avatar
The Bone
Thanks Chuck
Old Oct 5, 2017 | 11:10 AM
Irelands child's Avatar
Irelands child
Common with a 6.7!!!
Replace the coolant cap - it's gone bad
I've found a Stant 10238 is a better cap then the OEM Motorcraft. Then at this time, replace the secondary cap, Stant 10268 Either is about 6-7 bucks. Then, if you have any concerns with that hose being damaged from multiple times being 'sucked' together, I used a Gates 23981 at half the cost ---- and it was absolutely identical (oh and the Ford hose numbers are BC3Z8260B or BC3Z8260F if you insist on OEM)
Obviously, check those part numbers for your particular truck
Old Oct 6, 2017 | 07:38 AM
The Bone's Avatar
The Bone
I will check this out thanks for all the part numbers.
mo76
Dec 2, 2013 10:03 PM
f15olandscape
Mar 19, 2013 11:15 PM
Aerocook
Aerostar
Jul 24, 2007 10:37 AM
wresleu
1983 - 2012 Ranger & B-Series
Jan 14, 2005 08:26 PM
Copper93
1978 - 1996 Big Bronco
Aug 6, 2003 06:21 PM
