Lower Radiator hose?????
Old Mar 17, 2013 | 01:39 PM
f15olandscape's Avatar
f15olandscape
Hey guys, This morning I went out and checked the oil in my 1992 F150 4.9L I was looking around after and noticed my lower radiator hose was flat as a pancake in the middle? So I popped the radiator cap off and the hose went back to normal. Started up the truck let it run in my driveway for about 30mins took it out for a drive hose was fine didnt collapse. Came home and 3 hours later I was going out somewhere and figured I'd check it the hose was going flat again So I popped off the radiator cap and It went back to normal again. Anyone have any idea whats going on? Lower rad hose it 3years old, radiator is a year old, and thermostat and water pump are 2 years old Thanks
-Cory
Old Mar 17, 2013 | 01:47 PM
JWC 3's Avatar
JWC 3
Sounds like a bad cap . It should not form a vac. the valve in the cap can go bad .
Old Mar 17, 2013 | 01:53 PM
blue924.9's Avatar
blue924.9
it probably doesnt have a spring in it to prevent this. if it doesnt most people just coil a coat hanger around the inside of the hose
Old Mar 17, 2013 | 01:57 PM
88n94's Avatar
88n94
From what I have read lower radiator hoses are supposed to have a spring in them to keep them from collapsing. Mainly from collapsing when the engine is running and the water pump is sucking the coolant through the system to circulate the coolant. I would replace the hose.
Old Mar 17, 2013 | 05:07 PM
f15olandscape
Ok thanks that probably sounds like the problem that would be causing it. The cap is a few years old but probably something went wrong in it. Thanks
Old Mar 19, 2013 | 06:13 PM
f15olandscape
Replaced the cap, problem solved thanks again guys
Old Mar 19, 2013 | 11:15 PM
JWC 3's Avatar
JWC 3
Glad you got it fixed thanks for posting the fix . Lots of guys don't understand how a radiator cap works . They can fail either way . Pressure or suction .
Eli1644
Dec 1, 2014 06:09 PM
88fordranger
Dec 12, 2005 07:32 PM
wresleu
1983 - 2012 Ranger & B-Series
Jan 14, 2005 08:26 PM
Copper93
1978 - 1996 Big Bronco
Aug 6, 2003 06:21 PM
tmcalavy
Mar 6, 2002 10:08 PM
