collaped hose?
Old Jan 14, 2005 | 11:42 AM
wresleu's Avatar
wresleu
collaped hose?
My upper radiator hose is collapsed on my 3.0. This summer I put a new radiator on and all seemed fine at the time, but cant be certain. Yesterday I noticed the upper hose was collapsed. And it doesnt appear to be circulating through it. Any suggestions? Causes?
Old Jan 14, 2005 | 12:55 PM
87 XLT's Avatar
87 XLT
Sounds like a bad radiator cap, i'd replace it.
Old Jan 14, 2005 | 05:04 PM
texan2004's Avatar
texan2004
Did you replace the hose. They get old and weak. I agree with replacing the cap but I would consider replacing the upper hose as well.
Old Jan 14, 2005 | 05:40 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Well, it's usually the lower one that collapses as the pump is drawing water through it rather that pushing water into it. Is it overheating? Is it hot to the touch? Did you replace the thermostat, and if so maybe install it backwards? Does is only appear collaped on a cold motor; this would suggest a failing hose, as there is a suction in the system what draws coolant back into the radiator from the burp tank.
Old Jan 14, 2005 | 06:15 PM
wresleu's Avatar
wresleu
Yes after further investigation I have come to the conclusion that it only collapses when cold. Once the engine is warm and running/circulating...the hose if fine. Nope haven't done the tstat,hose or anything else. Backwards?? Its a 3" heater hose....is there such a thing as backwards?
Old Jan 14, 2005 | 08:26 PM
Rockledge's Avatar
Rockledge
He meant the T-stat, not the hose.
